1 (edited by falcon63 2016-01-25 18:00:35)
Topic: Boeing FlightFactor 777-200 GroundHandling Deluxe Set File
This is the Ground Handling Deluxe SET File, for the FlightFactor Boeing 777-200.
It includes the following automated vehicles totally surrounding the Aircraft with motion:
•    Two GPU Units and Cones: Right - Front
•    Two Catering Trucks: Right - Front & Rear Doors
•    Six Chocks: Front & Behind all tires
•    Fuel Truck: Right - Under Wing
•    One Container Loader: Front - Right
•    Three Luggage Loaders: Two on Left - Front & Back, One on Right - Back
•    Three Stairways: Two on Left - Front & Back, One on Right - Back
•    One Neoplan Bus: Left – Back, under wing near stairway
•    One Van: Right – Back, near stairway
When you select “Drive Up All” from the Plugin Menu, all vehicles start moving from a far away location on the lower left side of the aircraft and make their way to all assigned locations, surrounding the aircraft with automation. All equipment is carefully placed in their proper locations, ascent to their respective heights and barely create contact with their aircraft.
When you select “Drive Away All” from the Plugin Menu, all vehicles separate from their aircraft, some of which go on reverse and then switch to forward motion, until they all return to their respective starting location.
Note:
This file is only for the 777-200 Aircraft from FlightFactor and does not align well with the 777-300 model. You can use this SET file and modify it to fit the 777-300. Also, this file does not automate the opening and closing of aircraft doors or automatically connects the GPU units to the aircraft (for electric distribution). You still need to open the doors and connect the GPU units using the main aircraft menu.
Installation:
Download file from here or from: http://forums.x-plane.org/index.php?app … file=30180
Unzip the “Boeing777-200ERset.zip”
Place the “Boeing777-200ER.set” unzipped file in the:
“X-PLANE 10/Resources/plugins/GndHandling/Sets/Custom/” folder.
To use:
Select your FlightFactor Boeing 777-200 from the X-Plane Aircraft Menu.
Select GroundHandling from the X-Plane Plugin Menu and select “Drive Up All” to call all vehicles, or “Drive Away All” to recall all vehicles.
Requirements:
X-Plane 10.36-10.40 (64 bit only)
JARDesign Ground Handling
Remarks:
FlightFactor Boeing 777-200 is a registered trademark ® of Laminar Research
Ground Handling Deluxe is a registered trademark ® of JARDesign.
Download From:
From this site or from X-Plane.org Link: http://forums.x-plane.org/index.php?app … file=30180
