26 (edited by BluesmanEP 2016-01-20 18:18:31)
Re: X-Life public beta-3 190116 (Win & Mac)
Using the current x-life beta, and version 2.6B4 of the A320.  Xlife doesn't seem to see the transponder code correctly.  I've got it set as requested and EDDM tower keeps asking me to set the code.  Any ideas?
http://jardesign.org/forum/img/m/1148/t/p1a9g3lcb314g35ic1bd14ql1gf03.png
27 (edited by joomie 2016-01-20 18:46:04)
This is a bug.
TA/RA is not read correctly. set it to TA mode only.
for people who don't know the acronyms:
TA = Traffic Advisory
RA = Resolution Advisory (Annunciations of "Climb, climb! respectively "Descent, descent!")
That worked.  Thanks!
Yes, can not file a flight plan I get different errors when I try to file, but no CTD until I force the issue, and all the log.txt is giving is crash is due to X-Life ..  will wait to see how you want me to proceed JAR .
thank-you,
I love your plugin. X-Life is a very good addon for X-Plane.
Try this :
Traffic ON,  Flight plan : dep EDDM, ARRIV EDDL, ALTER EDDF, FL, Callsign
Export and ... (My X-Plane crashed)
Try this :
Where is the Log.txt?
Reason can be that EDDF is currently not ready for plugin.
Do you have EDDL and EDDM in custom scenery? Is needed.
32 (edited by TKurzweg 2016-01-22 09:19:05)
First thanks for the development of this software ! my ideas and wishes :
1. different voices for ATC ( ground , tower , center ect . ) ?
2. Menu flight plan : Callsign & airline like " Lufthansa " , " Air Berlin " ect . ?
3. different traffic for the airports in my flight plan and the airports used ?
My test version: Beta 3 190116 + FIX
Flightplans with EFASS and save to JarDesign A320neo. Import via menu "Flightplan" no problem.
Flights from EDDM to LOWW and back = no problems / crashes.
Also from LFMN to EDDH and EDDL = no problems / crashes !!! Works fine to me !
ATC Sound works good, but a "full-time-job" for one woman, he,he,he !
See my wishes and ideas on top.
Question:
Is it possible to use X-Life with FS Global Real Weather (FS9/FSX/P3D/XP) and SkyMaxx Pro ?
So, we prepare a hotfix for current beta 3, based on CTD reports. Please delete old .xpl files from X-Life folder and install new from this pack. No additional registration should be.
http://jardesign.org/forum/img/m/22/t/p1a9i2ll2i18im1321sut1vgs9ld3.jpg
34 (edited by sisik_stiv 2016-01-21 13:09:08)
Установил фикс, вылеты сима после нажатия generate f\plan не прекратились. Аэропорт EDDM с орга, планирую маршрут в lows. --=={This application has crashed because of the plugin: X-Life}==--
Still getting CTD when trying to file a flight plan.  Not getting any memory full errors from XP this time.  I notice when I enable XL even with low settings, memory usage jumps from just under 5GB to 7GB.  However, after a minute or so, it moves back to 5GB usage.  It wasn't doing this with the last version and was staying at over 7GB and giving memory errors.
However, still getting CTD when I try to generate a flight plan.  Have tried different destinations with the same result.  Also getting CTD when I try to import a flight plan.
36
By the way:
Which format is needed/ possible when importing a flight plan?
37
Where can I find the manual for Xlife?
currently there is none. it's beta test phase.
39 (edited by laohu314 2016-01-21 20:21:06)
Just tried a flight from EDDM to LOWW with X-Life. Worked well until CTD on descent ...
Logs attached
40
Since, you can use a generated plan or, you can use the Flight plan from the flight plan folder in the JAR A320 aircraft file or, generate one from an online and put it into the file and use it that way. I think I covered all the ways you can oh, hand enter and then import, that make several different ways right, the only one I have not tried is the last one. so if you have some time you might try an easy one please.
joomie wrote:
By the way:
41 (edited by captbullett 2016-01-22 00:14:00)
can't run with out a CTD I tried to delete the second Logtxt but would not let me your system is not working
But this is the issue (error message on the Apple error log   //*
9   libc++.1.dylib                    0x00007fff8f7e3e54 std::__1::basic_string<char, std::__1::char_traits<char>,    std::__1::allocator<char> >::__grow_by_and_replace(unsigned long, unsigned long, unsigned long, unsigned long, unsigned long, unsigned long, char const*) + 136
10  libc++.1.dylib                    0x00007fff8f7e3d23 std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >::append(char const*, unsigned long) + 113
11  mac.xpl                           0x0000000080ac3a26 ExecuteRequest(int) + 374
12  mac.xpl                           0x0000000080ad5875 AtcWidgetHandler(int, void*, long long, long long) + 325
13  XPWidgets                         0x0000000019b8a612 XPSendMessageToWidget + 86
B
Attachment icon bbox_log.txt 101 b, 315 downloads since 2016-01-21
Just want to say that this will be the definitive ATC plugin for XP and I can't wait for it to be stable and available at most airports. One additional observation I made was that I had OpenSceneryX renamed with an additional letter I front to force it to a different place in the alphabetical sorting but that caused a CTD when starting traffic because X-Life couldn't find OpenSceneryX. No big deal but I just wanted to mention it in case others have a similar experience. It was easy to find out from the log file.
43 (edited by sisik_stiv 2016-01-22 10:30:51)
Краш сима в аэропорту LOWW, при нажатии на кнопку generate plan в LOWS. 1 лог на А330, 2 лог на А320
44
joomie wrote:
By the way:
if your flightplan always entered to a320/330, you can import it to X-Life with this button
45 (edited by captbullett 2016-01-22 19:26:52)
14:23 PM EST Friday  and It seems that XP.org is down can someone confirm that for me I got on line but it took to long and then it was like not one person was logged on?
we do have a bad storm moving up the coast of the US, and it can be causing issue with communications and other everyday life.
B
I also had trouble getting onto the .org site. It's not completely down but VERY slow.
The storm could be responsible, although I don't know how it wouldn't shut it down completely.
47 (edited by captbullett 2016-01-22 20:56:03)
Ok, the .org is right where the storm is now. and the store is up the last time I checked
B
48 (edited by joomie 2016-01-22 22:48:24)
Does anybody get complete atc guidance after contacting approach (TOD has been reported to center before) until parking at the ramp start at the arrival airport?
I made a flight from LJLJ to LIPY (yes, i created the needed .dat & .txt files) and got a loop in the atc panel (see image).
This is something I always experience, when approach asks me to contact the tower on final.
http://jardesign.org/forum/img/m/436/t/p1a9loa6iv1flk1bpk1ups1kj8p1r3.png
49
I can't test this plugin any more as it is using an on-line weather and it interferes with SMPV3 .
50
Well, I use SMPv3 too and download online weather. And it runs.
