Topic: [old] GHDeluxe v.110116
This is Ground Handling Deluxe plugin by JARDesign v110116 distributive (Win 7/8, MAC OS 64 bit)
What new:
+Add ability to change Liveries using Menu->Plugins->GndHandling->Liveries
+Add 5 Liveries as example
+Improve registration system
+Add Instant News system
Download link http://jardesign.org/gndserv/download/GHD_110116.zip
     1. if need - Save your custom sets from ..X-PLANE 10/Resources/plugins/GndHandling/Sets/Custom/
     2. save your key.reg file from ..X-PLANE 10/Resources/plugins/GndHandling/
     3. be sure, that you use X-Plane 10.42+
     4. delete old «GndHandling» from ../X-PLANE 10/Resources/plugins/
     5. copy unzipped new «GndHandling» folder to ../X-PLANE 10/Resources/plugins/ folder
- If you have key.reg file from prev version
     6. Paste your saved key.reg file to ..X-PLANE 10/Resources/plugins/GndHandling/
     7. Paste your saved custom sets to ..X-PLANE 10/Resources/plugins/GndHandling/Sets/Custom/
     8. Your plugin is always registred
- If you perform New installation
     6. start X-Plane 64 bit and load default Boeing 747
     7. Use X-Plane menu and select the Plugins->Ground Handling->Registration menu and enter your email and the serial key. Next press the SEND button and please check your e-mail. within 1 hr. You should get activation code must be entered in the 'code' field and press CONFIRM. Your application must work well now. If necessary to reinstall, please use the same e-mail and serial number.
     8. activation works well with both MAC/WIN 64 bit
Re: [old] GHDeluxe v.110116
Hi!
Thanks for that and a request:
Make the GPU disappear (hide) when one hits "Drive Away All".
Cheers,
joomie
3 (edited by A350Pilot 2016-01-12 16:27:33)
Hey joomie,
if you want to, you can easily do this by your self. Just give a two Point Path for the GPU for Part two. When the GPU drives away, it disappears. You could see the Example in my FF B772F File here in the Forum under User Sets.
Greetings
Joachim
X-Plane since V10
Hi J.A.
Great work as always. Wonder when and if you will incorporate more pieces of equipment other than the bigger loader for larger aircraft? Baggage carts, smaller stairs for regional jets/prop planes, etc. Thanks!
