1 (edited by A350Pilot 2016-01-09 12:02:28)
Topic: FlightFactor B772F
This is my first Attempt. to build a Set for GndHandling. Hope, you enjoy it.
Before using this Set, it is very important, to read the Installation and Usage Info.
X-Plane since V10
Re: FlightFactor B772F
is it possible to change the loader to the new larger C model ?
Could you also add a catering truck, loaders on the right and cones ?
Safeflight
i am on the Work with it. But unfortunately, it is much more work to do, as thought before. So, please be a little patient.
I will post the new Set soon, when it is ready.
A Catering Truck on a Freighter? I don't think, that any Airline will pay that Cost for a max. of 6 Souls aboard.
Therefore, and instead of a Baggage Loader, i added the Van. Hope, you can accept this.
Joachim
X-Plane since V10
Joachim
I think he means that you can use it also with the PAX 777-200 because what falcon63 did is nice but i never see a luggages loader on a 777-200 only on the little bulkdoor.
It is always container luggages plane!!
Aaah, thanks for the Explanation.
But this  Set is for the Freighter only. I use the same Set for my Freighter. So, i place anything, that is needed for the Freighter.
If i have some Time, i will build a Set for the 777-200 PAX Version. But i do not promise to do that, because it cost much Time.
X-Plane since V10
