1 (edited by joomie 2016-01-02 14:00:49)
Topic: Bug: Different view behavior between circle view and pilotview
Hi!
Two screenshots of exactly the same situation:
view circle:
http://jardesign.org/forum/img/m/436/t/p1a818g2o01mva1uuk1c0512uss7l5.png
Pilotview being outside of aircraft:
http://jardesign.org/forum/img/m/436/t/p1a818hhc81pgs36l6l178dk1uj.png
One can see that the first view is correct. The catering truck hides the wing.
But the second screenshot shows the wing being before the catering truck.
Can show the same problem with iTow:
http://jardesign.org/forum/img/m/436/t/p1a81a6kn2h701o1v1rjh1nlcfff3.png
http://jardesign.org/forum/img/m/436/t/p1a81a72nnfr16g3hi21b981c7h9.png
Rgds,
joomie
Re: Bug: Different view behavior between circle view and pilotview
Could solve that by using the plugin X-Camera.
There you can setup different views and set the camera to a specific position.
If you forget to set the attribute "external view" you get the same issue. But if you enable
that checkbox all works fine.
