Topic: GPU doesn't move?
need a little Help, that could not be found in the Videos or in the delivered Sets.
Try to move the GPU on a Path from its Parking Position to the necessary Position in Front of the Aircraft.
Setting the Path works great. But the GPU doesn't move along this Path. Click on Phase 1 or Phase 2 let the GPU disappear.
Using one of the delivered Sets doesn't solve the Problem.
Also a Problem is, the the GPU appears when clicking Drive all up in the GND-Menu. When clicking Drive away, all Cars drive away.
The GPU doesn't move away from the Aircraft.
Are there any Solutions for my Issues?
Greetings and Thanks in Advance for your Response,
Joachim
X-Plane since V10
Re: GPU doesn't move?
Did you set the speed at least to 1 in the set editor's appropriate field?
If so maybe the GPU isn't programmed to move, in real you have to use an truck to move it. But that has to be confirmed by the developers..
Yes i did set a Speed Value of 3 in the appropriate Field.
So, it looks like the GPU is not programed to move.
Second Thing is how to get the GPU away from the Aircraft when clicking Drive all away in GND-Menu?
When it can not move, it should be disappearing. But it doesn't. Is there any Solution?
X-Plane since V10
Just click on the "H" in the control panel to hide the GPU.
Christian
5 (edited by A350Pilot 2016-01-04 16:04:21)
Thanks for your Response.
But that is not really a Solution, because i make my own Sets for every Aircraft. So, every Aircraft has its allocated Vehicles.
This Way i can, instead of using the Control Panel, use the GND-Menu Entries "All drive up" and "all drive away".
Joachim
X-Plane since V10
