Topic: Developers beta 301215 download (MAC OS only)
MAC ONLY Developers beta 301215
- panels "out of screen" fixed
- perfomance improve
So, is you are X-Plane scenery developer, you may use this version to check how good your WED atc-taxi-routes work with real traffic plugin. X-Life may read apt.dat files well, direct from Custom scenery folder. Also you can export apt.dat using WED to ../X-Life/Airports/ folder. In this case, X-Life will ignore apt.dat in Custom scenery and will read your XXXX.dat (XXXX - ICAO airport code) from ../X-Life/Airports/. Sure, you need do one more thing before testing - use X-Plane menu / Plugins / X-Life / Gates editor to set parameters for EVERY gate (batch edit supported). If you need some examples of propertly builded airports ATC-taxiroutes, you may just import any of this (http://jardesign.org/forum/viewforum.php?id=33) using WED and look into. Sure, you need registration serial. Please contact me direct via skype j.a.romanov (only way) for this.
If you are a regular X-Plane user - this version not for you, sorry, cause it not complete for regular users (have a lot of incomplets) but.. if you very curious X-Plane user - hmm.. yes, may be. This version may work in Demo mode (unregistred mode) with this 3 airports https://www.google.com/maps/d/edit?mid= … sp=sharing
If you click on every of this airport - you will find a download link for free sceneries for this airports.
If you use FMCar, please update your version (MAC OS now only this time) - it will be compatible with X-Life (useful to request ATC for FMCar and ATC will call FMCar for you and supply it with needed Ground Route).
Download link for FMCar ver 2.2r1 MAC OS - www.jardesign.org/fmcar/download/FMCar_2.2r1mac.zip
-------X-Life DOWNLOAD LINK-------------------------->
MAC ONLY Developers beta 301215 Download link -
www.jardesign.org/x-life/download/xlife_301215.zip
-------HOW TO / Example flight ------------------------>
-------FAQ------------------------------------------------>
Why MAC only? - I develop this plugin using C++ and X-Code (MAC staff). It is preferrable for me now. Yes, i will port whis plugin to WIN, but later stage. Port need just a time.
I see issues! Should I post here? - If you are scenery developer, your way - contact direct via skype to discuss some. If you are use X-Life for demo-flights - you can post, i will read, BUT for many-many your issues, please be sure what I have the same issues this time and know about this, cause plugin is incomplete and not for comfort using now. This is some another, earlier stage of development.
