Topic: Developers Beta 271215 download (MAC OS only)
Hmm.. I am not really sure is it good idea to post this developer version now, but..
..let it be! MAC ONLY Developers beta 271215
So, is you are X-Plane scenery developer, you may use this version to check how good your WED atc-taxi-routes work with real traffic plugin. X-Life may read apt.dat files well, direct from Custom scenery folder. Also you can export apt.dat using WED to ../X-Life/Airports/ folder. In this case, X-Life will ignore apt.dat in Custom scenery and will read your XXXX.dat (XXXX - ICAO airport code) from ../X-Life/Airports/. Sure, you need do one more thing before testing - use X-Plane menu / Plugins / X-Life / Gates editor to set parameters for EVERY gate (batch edit supported). If you need some examples of propertly builded airports ATC-taxiroutes, you may just import any of this (http://jardesign.org/forum/viewforum.php?id=33) using WED and look into. Sure, you need registration serial. Please contact me direct via skype j.a.romanov (only way) for this.
If you are a regular X-Plane user - this version not for you, sorry, cause it not complete for regular users (have a lot of incomplets) but.. if you very curious X-Plane user - hmm.. yes, may be. This version may work in Demo mode (unregistred mode) with this 3 airports https://www.google.com/maps/d/edit?mid= … sp=sharing
If you click on every of this airport - you will find a download link for free sceneries for this airports.
If you use FMCar, please update your version (MAC OS now only this time) - it will be compatible with X-Life (useful to request ATC for FMCar and ATC will call FMCar for you and supply it with needed Ground Route).
Download link for FMCar ver 2.2r1 MAC OS - www.jardesign.org/fmcar/download/FMCar_2.2r1mac.zip
-------X-Life DOWNLOAD LINK-------------------------->
MAC ONLY Developers beta 271215 Download link -
www.jardesign.org/x-life/download/xlife_271215.zip
-------HOW TO / Example flight ------------------------>
-------FAQ------------------------------------------------>
Why MAC only? - I develop this plugin using C++ and X-Code (MAC staff). It is preferrable for me now. Yes, i will port whis plugin to WIN, but later stage. Port need just a time.
I see issues! Should I post here? - If you are scenery developer, your way - contact direct via skype to discuss some. If you are use X-Life for demo-flights - you can post, i will read, BUT for many-many your issues, please be sure what I have the same issues this time and know about this, cause plugin is incomplete and not for comfort using now. This is some another, earlier stage of development.
Re: Developers Beta 271215 download (MAC OS only)
And one more.. yes, EDDM, LOWW, LFMN sceneries have static aircrafts what conflict with x-life aircrafts (busy some gates). In this case you need paste .dsf files what are not include static aircrafts to scenery folder. You can prepare it yourself with WED: Import scenery - Delete static - Export scenery OR you can ask me here  - i will give a link for download.
Hi, in The future when plugin Will be released, IT Will use real flight Plan and real Company or not?  Thanks for your work
This plugin build flightplan using  real ATC airroutes, like routefinder website, for example. It is possible to make use real CompanyRoutes, but this is details, cause now - i just create an "engine". For this "engine" does not matter to use timetable or autogenerated list.
Perfect, i agree with you, amazing plugin, thanks a lot
