Topic: EDDL Dusseldorf
By Eugeny (JAR) Romanov, for payware Aerosoft scenery.
http://www.aerosoft.com/cgi-local/us/ib … 2620,12594
http://jardesign.org/forum/img/m/22/t/p1a6dntd7gtvl3kn1df11uhq7v3.jpg
Re: EDDL Dusseldorf
Bonjour
Dans le répertoire aéroport d' Xlife se trouve deux fichiers: XXXX.dat et XXXX.txt.
En téléchargement parfois il n'y a que XXXX.dat .
Pourquoi pas les deux fichiers?
Cordialement.
In the airport directory Xlife is two files: XXXX.dat and XXXX.txt.
Download sometimes there are only XXXX.dat.
Why not both files?
Cordially.
Re: EDDL Dusseldorf
Phil231 wrote:
Bonjour
Cordialement.
Why not both files?
Cordially.
The ICAO.txt file is generated by the Gate Editor in XL. The author of ATC Routes can choose to set the correct sizes and ramp types in Gate Editor and generate the ICAO.txt file they then publish with the ICAO.dat file or they can choose not to do that. In this case, users can and should make their own ICAO.txt files in Gate Editor to their own preferences (which they should definitely do to make XL work properly).
