Re: [?STABLE?] v.1.2r3 (Win 7/8, MAC OS 64 bit) [OnCheck now]
Thank you captbullett. I shall keep this in mind.
Departing PHX today I did a sweet 7K+ ft/min climb-out...until I disconnected the AP and set climb rate to a more moderate 2500 until things stabilized and then re-engaged A/P above 10K ft.  Other than that, non-eventful flight...nice rain effects compared with the A320.  Did replace the 3D sounds with the latest version...apparently louder sounds = faster airbus.  I have no explanation of why that happened this time, perhaps weather change phenomena.  Maybe a problem with constraints.
53
Hello Mr. Romanov
Since Uploading the last Version I have no Metar Data enymore..What can be here the problem... when I go back to the first version Metar is back.
Hendrik
Testing right now. Thanks
I cant open A33O! XP10 Crash when i open aircraft.
[SASL] Starting...
X-Plane scriptable avionics library plugin snapshot 2.4.0 20151116 Commercial Edition
Loaded: O:\X-Plane 10/Aircraft/330/plugins/sasl/64/win.xpl (1-sim.sasl).
JARDesign 1D Sound Engine
Loaded: O:\X-Plane 10/Aircraft/330/plugins/sound1d/win.xpl (jardesign.sound1d).
JARDesign 2D Sound Engine
Loaded: O:\X-Plane 10/Aircraft/330/plugins/sound2d/win.xpl (jardesign.sound2d).
JARDesign 3D Sound Engine
Loaded: O:\X-Plane 10/Aircraft/330/plugins/sound3d/win.xpl (jardesign.sound3d).
[SASL] Path to panel: O:\X-Plane 10\Aircraft\330\aircraft.key
[SASL] Loading avionics...
0:00:34.771 I/FLT: Init dat_p0 type:loc_tak apt:LFBO rwy:14L
0:00:34.771 I/SCN: DSF load time: 75 for file Custom Scenery/Global Airports/Earth nav data/+40-010/+42-001.dsf (0 tris)
0:00:34.771 I/SCN: DSF load time: 63 for file Custom Scenery/Global Airports/Earth nav data/+40+000/+42+001.dsf (0 tris)
0:00:34.771 I/SCN: DSF load time: 2762263 for file Global Scenery/X-Plane 10 Global Scenery/Earth nav data/+40-010/+44-001.dsf (180082 tris)
0:00:34.771 I/SCN: DSF load time: 2805030 for file Global Scenery/X-Plane 10 Global Scenery/Earth nav data/+40+000/+42+001.dsf (193341 tris)
0:00:34.771 I/SCN: DSF load time: 2920370 for file Global Scenery/X-Plane 10 Global Scenery/Earth nav data/+40-010/+42-001.dsf (212615 tris)
0:00:34.771 I/SCN: DSF load time: 2994294 for file Global Scenery/X-Plane 10 Global Scenery/Earth nav data/+40+000/+44+001.dsf (176599 tris)
0:00:34.771 I/SCN: DSF load time: 74 for file Custom Scenery/Global Airports/Earth nav data/+40+000/+42+000.dsf (0 tris)
0:00:34.771 I/SCN: DSF load time: 2378007 for file Global Scenery/X-Plane 10 Global Scenery/Earth nav data/+40+000/+42+000.dsf (203868 tris)
0:00:34.771 I/SCN: DSF load time: 2239040 for file Global Scenery/X-Plane 10 Global Scenery/Earth nav data/+40+000/+44+000.dsf (174096 tris)
0:00:34.771 I/SCN: DSF load time: 2516676 for file Global Scenery/X-Plane 10 Global Scenery/Earth nav data/+40+000/+44+002.dsf (186133 tris)
0:00:34.771 I/SCN: DSF load time: 3074571 for file Global Scenery/X-Plane 10 Global Scenery/Earth nav data/+40+000/+42+002.dsf (292035 tris)
0:00:34.771 I/SCN: DSF load time: 1729264 for file Global Scenery/X-Plane 10 Global Scenery/Earth nav data/+40-010/+43-001.dsf (188266 tris)
0:00:34.771 I/SCN: DSF load time: 2212917 for file Custom Scenery/Aerosoft - LFBO Toulouse Airport/Earth nav data/+40+000/+43+001.dsf (0 tris)
0:00:34.771 I/SCN: DSF load time: 37279 for file Custom Scenery/Aerosoft - LFBO Toulouse Scenery/Earth nav data/+40+000/+43+001.dsf (0 tris)
0:00:34.771 I/SCN: DSF load time: 1992719 for file Global Scenery/X-Plane 10 Global Scenery/Earth nav data/+40+000/+43+001.dsf (247497 tris)
0:00:34.771 I/SCN: DSF load time: 1923223 for file Global Scenery/X-Plane 10 Global Scenery/Earth nav data/+40+000/+43+000.dsf (197374 tris)
0:00:34.771 I/SCN: DSF load time: 2180457 for file Global Scenery/X-Plane 10 Global Scenery/Earth nav data/+40+000/+43+002.dsf (180190 tris)
FlyWithLua: User switched to a new airport (or changed the plane). Script files have to be reloaded.
FlyWithLua V2.3.2.2 succesfully connected to XSquawkBox.
FlyWithLua Info: Lua engine (re)started. LUA_RUN = 1, SDK_VERSION = 210, XPLANE_VERSION = 10420, XPLANE_LANGUAGE = Unknown and XPLANE_HOSTID = 1
FlyWithLua Info: Discovered 9 HID devices.
FlyWithLua Info: Load ini file.
FlyWithLua Info: Searching for Lua script files
FlyWithLua Info: Sorting Lua script files
FlyWithLua Info: Start loading script file Resources/plugins/FlyWithLua/Scripts/RTH_3.0.lua
FlyWithLua Info: Finished loading script file Resources/plugins/FlyWithLua/Scripts/RTH_3.0.lua
FlyWithLua Info: Start loading script file Resources/plugins/FlyWithLua/Scripts/zzz_viz.lua
FlyWithLua Info: Finished loading script file Resources/plugins/FlyWithLua/Scripts/zzz_viz.lua
FlyWithLua Info: All script files loaded successfully.
0:01:13.307 D/State: Received: 0:6
0:01:13.896 I/ACF: Loading airplane number 1 with Aircraft/General Aviation/Cessna 172SP/Cessna_172SP.acf
0:01:13.896 I/FLT: Init dat_p1 type:loc_general_area lat:44.294018 lon:1.045000 ele(ft):3029.078125 psi:90.672935 spd(kts):71.945839
0:01:13.896 I/ACF: Loading airplane number 2 with Aircraft/Helicopters/Robinson R22 Beta/Robinson R22 Beta.acf
0:01:13.896 I/FLT: Init dat_p2 type:loc_general_area lat:43.148617 lon:0.526369 ele(ft):3653.498291 psi:162.229065 spd(kts):21.085148
0:01:13.896 I/ACF: Loading airplane number 3 with Aircraft/General Aviation/P180 Avanti Ferrari Team/avanti.acf
0:01:13.896 I/FLT: Init dat_p3 type:loc_general_area lat:44.221664 lon:1.363071 ele(ft):10890.046875 psi:310.010681 spd(kts):234.788666
error: mv_DRF == NULLsim/custom/xap/snd/eng_vol_01
error: mv_DRF == NULLsim/custom/xap/snd/coc_vol_01
error: mv_DRF == NULLsim/custom/xap/snd/gnd_vol_01
error: mv_DRF == NULLsim/custom/xap/groundserv/tow_vol
3Dsound Engine by JARDesign v.1.4
2Dsound Engine by JARDesign v.1.0
1Dsound Engine by JARDesign v.1.3
About the APU BAT button logic,and the rev throttle logic,they are wrong....pls fix it at next update.
57 (edited by hades.esp72 2016-03-31 20:43:59)
Good day.
Is posible that A330 read the navdata from "Custom Data/GNS430", as A320 2.6b4?
Thanks and best regards.
58
i had a problem to report..
engine start procedure: apu bleed ON, next you turn the start selector ON, wait for pressurization, next open the fuel on top...
ok but if you not open the fuel valve on the turbine they work normally all the flight...
how i can fly with fuel off.??
59
If you're referring to the fuel pumps, I think these planes can operate with gravity feed.  Now, shutting the engines off is another matter...thanks to gravity feed (I suppose).
Hi, i have a problem wich i cant solve. Do not know if it is normal, dosen seem so.
In the 3D view in the cockpit (wehn i look forward) or the panel fwd view, i don't hear the engines  even if i full throtle for TO. I hear them if i turn backwards in 3D view but forwards i cant apreciate the sound or just very little. I just viewed some videos like  on youtube about the JAR 330 and an all of them i can see how during TO i can hear the negine very clear.  Not so so low as on my Windows.
Would apreciate some suggestion.
Greeting and thanks,
AnatolRohé. Spain, Palma de Mallorca
61
Just checked the problem. It was cause of 5.1 stereo. Tried it with 2.1 and works really great. Selfsolution
Hello, i've recently purchased the wonderfull A330 (thanks a lot mr. Romanov). I'm running under Mac El-Capitan, X-Plane 10.4 the v.1.3r3 and i had the problem described after on the v.1.2r2.
My problem is the following : the truck of the pushback and towing does not seems to work correctly, i've search for a problem like this one but i didn't find any clue so i've re-install the folder A330, but it goes on. When the truck come to the plane, he make a good approach, move forward to the gear and continue throw it, then it realized his mistake and make a u-turn and try again, fail and it re-start again. I joined a video of this, it makes only few minutes but i've let it continue hours and it does not fix.
The problem might come from me, I hope you will be able to help me,
Best regards, SGN
PS: Forgive for my english i'm not native english speaker.
Link for the video https://www.dropbox.com/s/pj7d4aubj1szu … 1.avi?dl=0
I always find this happens if the GPU is still connected as the tug is approaching. Make sure there's no other vehicles around the aircraft and give it a try
64
Indeed, it was the problem. Thanks for your very quick answer, now it work perfectly fine and the pushback scene is absolutely beautiful !
Best regards, SGN
Glad to hear! Happy flying
66 (edited by cartayna 2016-05-07 17:36:57)
Do you guys have the problem that when you operate with the knobs the cursor gets stuck, and is impossible to select an altitude, a speed, a heading..? and in general when i press any kind of white knob in the plane is stuck for a few seconds...  made a video of it... it cant be now the computer, for i am running on a recently installed x plane with an imac of 24gb memory, 4gb video and intel core i8 with 4ghz.. they did not have anything more powerful in apple with imacs..getting desperated with this airbus.  https://www.dropbox.com/s/wb47ink60hy3c … k.mov?dl=0
67
Hello
I am coming back to X-plane after a year of not flying and I cannot make this wonderful A330 to work (I updated X-plane to 10.45 and my version of A330 is 1.2r1 .  There seems to be no relevant menu in the plugins (just pushback and sttings)???
thanks
JEFX
68
Can anyone tell me if this update will allow me to use AirFMC with the A330?
69 (edited by captbullett 2016-05-19 03:22:25)
I can tell you airFMC will most likely have a conflict when you try to use the MCDU and program the A330 which you must do.
the airMCDU is only for aircraft like the 737 that did not have it's own MCDU where the developer did not want to develop his own MCDU and went to the airMCDU product to complete the project because he wanted to have a pop-up MCDU.
not to say you can try if you want to but you will most likely get a freeze of the computer screen.
can you tell by now I have tried the product and had a conflict.
Happy flying,
JEFX wrote:
Hello
thanks
JEFX
so, hate to here this but can you send a log.txt
Love your plane, but whenever I access a menu overhead e.g. settings and then i exit the menu the plane tries to kill everybody aboard by going into a >90 degree bank and nose down and trying to crash into the ground. Tried to do that at FL330 (now i know I can do a looping with this thing.....) and whilst capturing the ILS @ EDDF. Not a lovely thing to do....
72
Have you tried to Pause the sim then make the adjustment then un-pause and continue the flight this happens some times when you most likely should have had everything set and the sim is telling you to not do something at this time.
Yes, I know you don't like the answer but this is a simulator not a game to works different than a game engine and with it come different behaviors.
this way you won't have unhappy PAX
Happy Flying,
Happy Flying,
Thx for the answer. Didn´t have this problem with the A320 actually. By the way, is there also some CRZ page in the A330? In this A320neo it pops up upon reaching CRZ FL( I flew every in the market obtainable A320 starting with the PSS A320 for FS2k2, and in every plane the CRZ Page popped up in a different time...;)).
74
Hi JAR
I went back to v. 1.2.r2  the last stable version  because of diverse problems with v. 1.2r3 that I couldn't locate if they are connected with XL or A330 specific problems.
Using this stable version I got 2 serious problems:
1. On CRUISE under normal conditions, AP disconnected, causing speed to increase and aircraft to climb - although AT stays green.  After activating AP aircraft was stabilized and went back to cruise ALT and SPEED.
2. During descend I disconnected AP at 1000 ft while at landing configuration (speed, full flaps and gear down) aircraft got suddenly nose up and engines to CLIMB. I pushed the stick hard forward and could managed situation but descending level went too high.....
75 (edited by WayneG 2016-06-05 21:49:42)
Hello Mr. Romanov, I am not sure if these are issues but i believe they may be. I am having some issues, The VORS are not showing on the MFD, Just frequency's instead of names and also there is another issue if you go over 310kts where your maximum is 330kts your autopilot disengages and your not even in the red zone where the speed tape is. Also another problem i have noticed, WXR weather radar indicator is not showing on the MFD either and i am not sure but i think it does on the real aircraft.
