Topic: GHD Commands
I have written a LUA script that calls the "jd/ghd/driveup" command at a specific point in my startup checklist.
However, the command does not run until I have selected 'Show Control Widget' from the Plugins menu once - After this, the LUA script works fine.
Does anyone have any thoughts?
Re: GHD Commands
JARDesign 330 airliner x-version is also here. Are you guys ready to follow this and get help from this version. If you really want then i stay here and get everything from you. You never make paper writing service change in the x-version because it is important for those who take it.
3 (edited by VordFilly 2021-07-22 15:15:00)
Re: GHD Commands
JARDesign 330 airliner x-version is also here. Are you guys ready to follow this and get help from this version. If you really want then i stay here and get everything from you. But better use employee monitoring software for it
