Topic: FMGS flight plans modifications when in flight
How to modify the flight plan when we are in fllight ?? For example :
The plane is planed to fly to several waypoints such as A,B,C,D. The target is A. But ATC wants the plane to go straight to C.
How to do it ? Click in front of C, hold way point.. are not usefull. In Boeing 777 you do that, then click in front of A. You valid. The plane goes to C which is now instead of A.
The only way I see for the time being is to clear A, B as we do about discontinuity.
Is there someting quicker as we do in Tripple Seven ???
Re: FMGS flight plans modifications when in flight
Press DIR (=Direct to) key, click button next to the waypoint you want to fly. And then the key next to insert.
This only works if you DIR TO a waypoint that's already in the flightplan (LEGS). But what if ATC in their infinite wisdom sends you to a fix of VOR that is not in your flightplan? Now you need to modify your LEGS page and that's time consuming.
Thanks Homer. It runs quickly as you write.
Thanks also TD Plane. You are right.
Best regards to both of you
