1 (edited by ashley24uk 2015-09-17 08:15:18)
Topic: Does not work with Peters A319
HI everyone
I have a problem where for some strange reason I can not build my own set for peters A319 the ground handling object do not show up at all.The markers show up when build my own set just not the objects any idea why this may be?
Re: Does not work with Peters A319
That is probably related to the FBW plugin. Somebody else had the same issue with the A380. I experienced the same with the A350 as well. They all use the FBW plugin by qpac.
As i can check on my side, GHD loaded with a350 with this FBW plugin
Not have another aircrafts and cant check.
http://jardesign.org/forum/img/m/22/t/p19vde261623u1cr61nin139nes63.jpg
Thats what I though too. But making the set was fine, with the aircraft systems all off. But last week I made a flight and after I powered the plane up, the ghd would not appear anymore.
I just did another test. At least for the A350 the apu is the problem. Once you switch on the apu generator all vehicles vanish.
yeah I cant even build a set for peter A319 he doesn't have qpack its very basic works off xfmc. I tried to build
a set the yellow marker appears as soon as I press phase 1 nothing happens it doesn't show at all
even when I don't build a set and just click on drive all up their not their
He uses the qpac FBW plug in, which has nothing to do with the fmc, only with the FBW. Same for his A380.
I tried to build a new set for SSG E190LR and as the build set panel appeared XP CTD with a log showing that the ground handling plugin was the cause of the crash. It has happened with SSG E170 and FF A350.
Using XP10.40 on Windows 10. All the predefined sets work with FF SSG b748 Heinz B788 but not A380
Mike
Is this happen every time?
