Topic: Pushback Issue
I am using the A330 v 1.2r2.  The pushback truck will connect but I never get a message via the intercom and I can't pushback as the directional triangles never show up on the pushback graphic that appears on the left side of the screen.  I've watched the pushback tutorial video a number of times and can't figure out what I'm doing wrong.  Eventually the pushback truck becomes parked at an angle.
Re: Pushback Issue
I have similar issue with a pushback but with minor differences. Some times pushback just rolling around the nose gear and can't connect to it.
Re: Pushback Issue
I've resorted to using a free pushback plugin but it doesn't allow me to turn the aircraft.
Re: Pushback Issue
С буксировкой проблема. Буксировщик катается вокруг носового шасси без конца и не прицепляется. Как поправить ?
Re: Pushback Issue
Скорее всего до вызова буксировщика вы повернули колесо в сторону. Поставьте ровно и должен прицепиться.
Re: Pushback Issue
Действительно заработало. Спасибо!
