Topic: GND Handling breaks some sounds // [Patch included]
Just want to say, great some with the plugin. I do enjoy it a lot.
Only issue I have spotted with it is a weird one. So far I have only flown the 727/732 so far with it installed. With the 727, it breaks the autopilot disconnect sound, the marker beacons sound, and the GPWS 50 ft callout sound. With the 732, it only breaks the marker beacon sounds.
Will test out more planes to see what else may be messed up sound wise.
Re: GND Handling breaks some sounds // [Patch included]
I think need build next version with optional "disable" GHD sound function to avoid sound-conflict situation.
First off I have to say I'm ashamed at how long it took me to figure this one out.  I re-installed X-Plane, all audio drivers, OpenAL, even my OS among other things trying to figure out why *some* sounds didn't work.  I only have a few basic plugins installed so I never thought that might be the issue.
Essentially *some* sounds in aircraft didn't work.  The starter in the DC3, the switches in the SAAB 340A, the rotor in the 412, it was odd... most planes were unaffected and others were in very small ways.
After entirely too many hours of fiddling with settings I figured out it was the Ground Services plugin.  I came here to post these findings and see Chevy beat me to it smile
Anyhow the plugin is now disabled and all is well.  Hopefully this is something JAR can take care of in a future release.  Please let me know if you'd like me to provide any additional information to help.
Ok. Thanks for this info anyway. I will invent some.
Also sounds in the x737 are broken, with plug in active.
Ok. I prepare patch. I hope this patch will solve sound problems if happen. You can find instruction inside .zip
If will be Ok (please report!!!) I will post this with update.
Cool… sounds on the x737, working again.
In a320neo sound also appeared. Excellent work. Thanks Eugeniy!
OS w7 64bit XPlane10.36 (Steam) I7 4770 RAM 16Gb VIDEO GTX770 2Gb
Aleksey Dekterev
thanks for report
Thanks Evgeny, A320 sounds well for me too.
good! very good!
12 (edited by chevyrules 2015-09-09 23:30:57)
The sounds work now with the patch thanks! But I forgot to mention after I did a flight last night with the 727, the plane doesn't properly track a VOR/ILS properly or turn to the set heading( it would show in the HSI as heading 340, but the plane would be flying 10-15 degrees off).
Uninstalled the gnd handling and flew the same route and had no problems.
I am not sure. GHD not intersect with any AP or NAV systems.
Just to confirm, I have the same problem as Chevy with the FlyJsim 727, the patch solved the sounds but the aircraft is not tracking VOR's correctly. Once the plugin is removed the problem disappears.
Also with the FlyJsim 732 I am also losing my flight director and autopilot panel lights when the plugin has run before the flight. Again, no issues once the GHS is removed.
On the plus side no problems with the FF 777 all good there. Hope this feedback helps.
We just complete a numbers of tests for reproduce reported issues. So, not find dependence btw GHD on/off and that issues.
Anyway you can contact direct skype "cheag_slava" to discuss this.
I just did some more testing and for me at least, it was X-FMC causing the issue. I uninstalled X-FMC and the 727 now tracks VOR's and ILS's correctly. So something about X-FMC doesn't play nicely with the GND handling plugin( or vice versa).
thanks for report
Hi, the previous issues I had posted above have now disappeared, I am not sure what I changed or what cured it, but it all seems to be working well now. A little strange, I thought it was a problem with a separate plugin, so I simply removed them all one by one. After removing FlyWithLua the GHS started working perfectly. I have since added all my plugins back, including the FlyWithLua and everything is still working fine. Very odd, but Im not complaining....lol
Just thought I would post an update. Thanks for your quick responses. Look forward to future updates
Hi that's strange because I use FlyWithLua without any problems.
I`m using it for atmo colors and scattering.
