Topic: Texture Sets
Since the plug in is now released, I'd like to post again my textures for the vehicles.
Currently available:
Catering Truck:
- Gate Gourmet
- Sky Chefs
- Sky Catering Kitchen
Bus:
- Lufthansa
- Clouds Lufthansa
- Frankfurt Fraport
- American Airlines
- Delta
- Generic
Stairs:
- Globe Ground
- Swissport
http://i621.photobucket.com/albums/tt298/Justinkutzner/a330_230_zpsbptfi27u.png
http://i621.photobucket.com/albums/tt298/Justinkutzner/a330_231_zpsqz54hhnl.png
http://i621.photobucket.com/albums/tt298/Justinkutzner/a330_236_zpshseuhe5f.png
http://i621.photobucket.com/albums/tt298/Justinkutzner/a330_233_zpsgnkrw2fc.png
http://i621.photobucket.com/albums/tt298/Justinkutzner/a330_234_zps26lyzh0c.png
http://i621.photobucket.com/albums/tt298/Justinkutzner/a330_232_zpsbxs7ukqb.png
http://i621.photobucket.com/albums/tt298/Justinkutzner/a330_235_zpsaazvd5ww.png
http://i621.photobucket.com/albums/tt298/Justinkutzner/a330_207_zpsfwu8t4ei.png
http://i621.photobucket.com/albums/tt298/Justinkutzner/a330_224_zpsk9mm8izj.png
http://i621.photobucket.com/albums/tt298/Justinkutzner/a330_149_zpssyfnznse.png
Get them here: http://forums.x-plane.org/index.php?app … file=26998
Suggestions welcome!
Re: Texture Sets
Bravo! I am sure, if this plugin will be popular, need add some liveries manager (depend of loaded airports may be..)
Re: Texture Sets
Thank you, yes a livery manager would be good. That way one can take off using one set of textures and use another after landing. smile
Re: Texture Sets
very good work...
Re: Texture Sets
Great work! Can someone post the psd file so, we can make more texture sets!
Re: Texture Sets
Slava will post paintkit very soon.
Re: Texture Sets
Great job
I need some further explanations to use it
I understand I have to create a folder names liveries + myliveryname
I see also in your example a "default" folder inside the liveries ; does it mean it's a copy of the main default folder "cars" ?
Do I have to put your paints named default in this folder ?
Finally what the file "mylivery name" have to contain ? all your "default" files ie Cat_SCK as it is or renamed catering SCK png ?
Gérard
Re: Texture Sets
Dear Jusku
I have installed your amazing liveries inside the plugin
I cannot use Fra and LH clouds ; some obj seem missing for those files
The cars appear grey
Cheers
Gérard
Re: Texture Sets
I confirm for Fra airport and Luft clouds
The following cars appear grey
GPU
Fuel
Stairway
Something seems wrong in the obj
Cheers
Re: Texture Sets
Updated to work with V220116
Downloadable in livery packs. Simply unpack the downloaded folder, copy it and place it in your livery folder. Example for the Airberlin pack: X-Plane 10.42\Resources\plugins\GndHandling\Liveries\Airberlin
Re: Texture Sets
Great
Now everything is working !
All tne best
Re: Texture Sets
Hi Jusku
Could you for the 2 luft, Fraport and AA
Put the coresponding logos on vans and stairs ?
Thank you in advance
