Topic: [old] GHDeluxe v.280815
Download link - http://jardesign.org/gndserv/download/GHD_280815.zip
This is Deluxe version (need registration), but may also installed as "a330" version (not need registration in this case).
- if need - Save your custom sets from ..X-PLANE 10/Resources/plugins/GndHandling/Sets/Custom/
- be sure, that you use X-Plane 10.36
- start X-Plane 64 bit and load default Boeing 747
- Use X-Plane menu and select the Plugins->Ground Handling->Registration menu and enter your email and the serial key. Next press the SEND button and please check your e-mail. within 1 hr. You should get activation code must be entered in the 'code' field and press CONFIRM. Your application must work well now. If necessary to reinstall, please use the same e-mail and serial number.
