Sad about Skype, but anyway - to support this issue - need to read Log.txt file saved just after you try "Set TCA On". Sure, you may attach it here or send it to the Skype chat. Skype chat is preferable, cause this board is a public place and anyone may get some information about your computer from Log.txt file.
Log.txt file sent by Skype as requested.
Mr. Romanov,
Thanks for the help and support in Skype Chat.
It was very useful and the problem was solved.
Thanks again
78 (edited by ukflyer 2021-12-21 14:25:59)
how come there is no thrust mode showing on the ECAM like in this picture
http://jardesign.org/forum/img/m/1910/t/p1fnem3b7s1lhhsqsbt217veevc3.jpg
79 (edited by ukflyer 2021-12-21 17:07:17)
should the plane be banking 30 degrees at 30,000 feet, seems too much
can we have better cockpit textures the current ones are not very realistic
any possibility to add librain as an option to a future update?
82 (edited by ukflyer 2021-12-24 19:38:33)
autopilot is quite unstable in pitch when accelerating to new selected/managed speeds, could this be smoothed out?
83
unrealistic rate of climb (over 10,000) when selecting lower speeds
84 (edited by ukflyer 2021-12-28 10:16:43)
Sadly - no details in your post. Please explain some.
What (lower) speed was selected? What was the climb Rate? What GW and CG was?
What mode (FMA) you fly in this moment? What "realistic" Climb Rate should be in this situation
and (if possible) - link to docs where you take "realistic" data.
86 (edited by ukflyer 2021-12-28 12:15:53)
Climbing while in managed speed, then change it to selected speed and decrease it by 30 kts or so.
GW 55,850 kgs. Screenshot shows 6,400 but i've seen greater. Speed and altitude changes should be smooth and not huge in case of crew and their tolleys big_smile
BTW i really like this product, best Airbus for x-plane smile
http://jardesign.org/forum/img/m/1910/t/p1fo0453a715pc1voc1i266901etn3.jpg
Edit: this one's greater than 6,400...off the scale!
http://jardesign.org/forum/img/m/1910/t/p1fo0fe6huumm1d673r1cj4s5b3.jpg
87 (edited by ukflyer 2021-12-28 09:03:24)
Is there a way to disable the tooltip when in MCP MANIP STYLE 1?
88 (edited by ukflyer 2021-12-28 14:00:05)
The aircraft doesn't seem to want to accelerate at CDU selected altitude after thrust reduction, do you also have this? There are no speed constraints at waypoint GM..
http://jardesign.org/forum/img/m/1910/t/p1fo0f83ee1t1p6k10j5oec9v3.jpg
http://jardesign.org/forum/img/m/1910/t/p1fo0f83eesad1t9c1ja71p4g1bbo4.jpg
When acf fly with "hold speed with constant thrust" (like CLB mode) - and decrease target airspeed - you will get more VS.
91 (edited by ukflyer 2021-12-29 09:04:58)
ok thank you, seems odd that the plane will want to climb that fast!
Is it normal for the plane to hold 160 kts on departure when it should be accelerating at acceleration altitude? I see in youtube videos that it should be going faster...
First of all, need to determinate where from this issue come. If you a well-qualified airbus/sim pilot and are you sure that everything that you do - right, please contact me skype j.a.romanov - we will do flight together and will see what happen wrong. But yes, you need also check another kind of issue on your side, like conflict with some other plugin what you have installed and use in the same time, or (excuse me) wrong pilot operations.
thanks for the offer, just by using toliss and watching youtube i notice some differences, but not sure if i'm programming the CDU correctly. Normally there is an acceleration at the acceleration altitude but don't see this in your airbus smile
So, you want to say - aircraft flying V2 speed all the time up to 10000?
No more answers for you, sorry - just offer to make test flight to see how you operate it.
95 (edited by ukflyer 2022-01-12 21:45:33)
hmm seems to be on certain SIDs, EGKK  RWY 26L BOGNA 1X for example, KKW06 first waypoint says MAX 220 IAS but CDU is putting in the 160 kts speed restriction. I also did a departure from LFSB where the 160kts didn't appear and it accelerated as normal. Maybe i will do more testing!
96
please could pfd brightness switch be fixed in next version? thanks
Hallo Jar-Team,
we have been waiting for a new update for the A320 for over a year now and I am eager like a bow for the update.
Is there now a realeas date or a prospect of a reales that you can give us as a Comunity ?
Many greetings
Peter
Hey,
when will we be able to use Plane .55r2 ?
Because it crashes for me right on loading back to Desktop. I'm very sad since I paid lots of money for this. Am I able to have a refund if it does not work ?
Greetings smile
yasinouadria wrote:
Hey,
Greetings smile
Actual version 3.8 work well with 11.41 and 11.55
If you have crash just after loading - please www.support.jardesign.org with Log.txt file saved just after crash happen - we will check and inform you about a reason.
100 (edited by yasinouadria 2022-03-15 21:57:49)
Hey,
it finally worked thanks smile Iam pretty satisfied with the Product unfortunately. It just needs some love. For example the BSS Soundpack is very good.
