Topic: YSNF: cannot create xlf file
X-Plane crashes when I try to create .xlf file for YSNF, Norfolk island, Australia. I tried 1) letting X-Life generate the file from scenery, 2) creating a minimalist file from scratch with a text editor (geographic coordinates extracted from Google Earth), 3) copying another airport file and modifying the coordinates.
Same result: crash!
Here's the log:
log.txt for X-Plane 11.50r3 (build 115033 64-bit)
compiled on Sep  2 2020 14:04:45
X-Plane started on Sun Nov  1 09:11:09 2020
This log file is generated automatically by Laminar Research applications and contains diagnostics about your graphics hardware, installation, and any error conditions.
If you need to contact tech support or file a bug, please send us this file. NOTE: this file is rewritten every time you start ANY of your X-System applications.
Windows 10.0 (build 18362/2)
This is a 64-bit version of Windows.
CPU type: 8664
Physical Memory (total for computer): 17022767104
Maximum Virtual Memory (for X-Plane only): 140737488224256
CPU 0: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz  Speed (mhz): 2592
X-System folder:'C:\X-Plane/X-Plane 11/', case sensitive=0
XL: 1 : JARDesign plugin: C:\X-Plane\X-Plane 11\Resources\plugins\X-Life\News/news.txt file updated.
XL: 1 : MessageGreen: X-Life Traffic by JARDesign Ver.v.4_210718
XL: 17 : MessageGreen: Approved Airport List for X-Life Updated!
XL: 25 : Bluebell XL library find: C:\X-Plane\X-Plane 11\/Custom Data/Bluebell XL/
XL: 25 : X-Life Airac Cycle:  2009
XL: 25 : X-Life Airac Provider: N
XL: 25 : X-Life Airac Data:  13/AUG/2020 - 10/SEP/2020
XL: 25 : MessageGreen: NavData:  2009 ( 13/AUG/2020 - 10/SEP/2020) from C:\X-Plane\X-Plane 11\Resources\plugins\X-Life\navdata/
XL: 25 : X-Life NavDataPath =C:\X-Plane\X-Plane 11\Resources\plugins\X-Life\navdata/
XL: 25 : X-Life NavDataProcPath =C:\X-Plane\X-Plane 11\Resources\plugins\X-Life\navdata/Proc/
XL: 30 : X-Life:Curl (CurlUpdateSheduler) = YSNF
XL: 30 : JARDesign plugin: C:\X-Plane\X-Plane 11\Resources\plugins\X-Life\Metar/YSNF.TXT file updated.
XL: 30 : X-Life plugin ver.v.4_210718 detect crash.
XL: 30 : Memory dump saved to x-life.dmp file
XL: 30 : Please send this log.txt file and x-life.dmp file (from X-Plane folder) to support@jardesign.org !
Dump attached.
Any clue? If you have a debug version, I'm can run it (I'm a software engineer, now maths/computer science teacher).
I'd appreaciate a late X-Life revision, including beta.
Attachment icon YSNF.xlf 310 b, 186 downloads since 2020-11-01
Re: YSNF: cannot create xlf file
You can´t create an xlf-file with X-Plane 11.50 (see http://jardesign.org/forum/viewtopic.php?id=11819).
Thank's for the link. I've create several with 11.50 so apparently it does works for "some", though they have to be created with a text editor for most. Once the initial .xlf is created, X-Life can read it and the Airport Editor can be used.
Weak support, many bugs. Not sure where JARDesign is going...
Ate you looking for assistance and help to write an academic essay? Don’t worry and just follow this blog and I prefer to check dissertation writing service uk for quality writing task. They are assisting the students in the best regards to letting them have the idea and understanding of this procedure.
