1 (edited by patriziolubrani 2020-09-13 22:12:19)
Topic: X-Life Editor Crash X-Plane
Hi, I only recently registered so I send a greeting to everyone.
I am trying to open X-Life Editor (free vers), again recently, from the plugin menu and X-Plane crashes. It happens with both version 11.41 and the latest 11.50. But using X-life does not normally happen. It only happens if I choose to open the Editor.
Then I changed airport from LIRA to LIRF and then LIRU and then LIRS and then another. In these others it doesn't crash but I don't see any Pink or Purple lines and it doesn't even let me draw lines. In LIRA it crashes maybe because it is the basic one and I have not installed any LIRA?
X-Plane 11.41 (64-bit)
iMac 27" con display Retina 5K
Processore Intel Core i9 8‑core - 40 GB di memoria DDR4 a 2667MHz
Radeon Pro Vega 48 con 8 GB di memoria HBM2 - Unità SSD da 1TB
Re: X-Life Editor Crash X-Plane
Now I have downloaded LIRA scenery pack from gateway, so now there is the airport folder in Custom Scenery, I am following the lines of the editor manual, however, I don't see any purple lines, it doesn't let me draw lines.
any help?
