Topic: a320neo (JARDesign) Set
Full functional (really GPU an FuelTrack connect) will work after your next a320neo update.
http://jardesign.org/forum/img/m/22/t/p19spfm852i2ac51m9013t46hn3.jpg
Installation - put .set file to ...X-PLANE 10/Resources/plugins/GndServices/Sets/Default/ folder
To have it work with more when a330, user should have registered plugin.
Re: a320neo (JARDesign) Set
What do you mean for " will work after your next a320neo update"  ?
You mean that this file will work with a future update thas doesn't exist now ?
Or this file is ok also for the current version " VER 2.3 r4 " ?
Luigi
Luigi
I workon ver 2.5 now. This update will use all GHD functions (autoattach GPU, open/close doors, show/hide fuelpanel)
also it will have fixed "roll" at fbw system, fullrange weather radar and will ready for custom soundpacks like 330
The A320neoby.set is working with the latest beta 2.5b1.
I noticed that the fuel electric door below the wing remains open when using the GND_plugin Fueltruck.
If using the default fuel truck it closes in sequence when disconnecting the truck.
Maybe a data reference is missing.
Hi, I found that the front loader is not able to open the front cargo door by itself, despite it being open on your screenshots!?
Luigi
I work on ver 2.5 now. This update will use all GHD functions (autoattach GPU, open/close doors, show/hide fuelpanel)
custom sound packs like 330-Guess those will be pay-more-ware like the 330?
