Re: JD320 Airliner ver 3.6 WIN/MAC 64 bit (X-Plane 11.50/11.41)
michaelnemma44 wrote:
So is the New EFB Tablet going to be in the V4 or is it still planned for the final release of the V7
Now we have version 3.6. If you know something about "your V7" - please share this info!
the tailrudder are very sensitive when i make small adjustments on final. and the fly with lua landingrate game does not work with this plane. but this plane is still amazing now!
53
lua landingrate is a some widget?
if so - you may take win.xpl and mac.xpl files from R2 ZIP at this folder:
/plugins/fmgs/
When i land. Plane starts to "shake" for like 2sec and the main wheels are like Lifting from the ground. It looks really wierd
55 (edited by bwg100 2020-09-12 15:08:52)
bwg100 wrote:
Hi, on older versions there was an option on the MCDU menu to display a shortcuts toolbar which gave quick access to functions such as towing and fuel. I can no longer see that. Has it been removed?
Please read "WHAT NEW" part in the first topic.
Thanks for pointing me to that.
One thing I have noticed is the performance of the plane seems different. For example, on TOGA I was able to take off from Innsbruck LOWI in previous versions. Now I reach the end of the runway before the "rotate" speed is reached.
Is this intentional or am I overlooking something obvious? (Fuel loads etc. are the same as before).
I noticed several time that JD320 starts for a go around a waypoint when we modify the flight plan.
I just got it, while entering an arrival. I think it occurs when we modify the flight plan very close to a comming waypoint.
Here are the last log lines:
Xchecklist: prefs file found, Saving these values.
Xchecklist: Checklist window position win_pos_x1 left = 11 win_pos_x2 top = 1088 win_pos_y1 right = 378 win_pos_y2 bottom = 955
Xchecklist: TRANSLUCENT: 1
Xchecklist: SHOW_CHECKLIST: 1
Xchecklist: COPILOT_ON: 1
Xchecklist: VOICE: 0
Xchecklist: AUTO_HIDE: 1
Xchecklist: SHOW_WIDGET: 1
Xchecklist: SHOW_GUI: 0
FMGS: 3969 : add Leg: R09,IF,GB09F,36.106847,-5.403039, ,0.0,0.0,1,1500,0,1,160,0,2,0
FMGS: 3969 : add Leg: R09,RF,GB096,36.150164,-5.378714,2,GB409,89.9,1.6,2,380,0,0,0,0,0,0
FMGS: 3969 : add Leg: R09,TF,RW09,36.150881,-5.358100,0, ,0.0,0.0,89.0,1.0,1,61,0,0,0,0,3,1
FMGS: 3969 : add Leg: R09,TF,GBM02,36.151669,-5.335536,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,0
FMGS: 3969 : add Leg: R09,TF,KUXOX,36.157414,-5.166344,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,0
FMGS: 3969 : add Leg: R09,TF,PIMOS,36.150361,-4.893472,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,1
FMGS: 3969 : add Leg: R09,DF,UPMUP,36.000000,-5.000000,2, ,0.0,0.0,1,4000,0,1,230,0,0,0
FMGS: 3969 : add Leg: R09,HM,UPMUP,36.000000,-5.000000,1, ,0.0,0.0,305.0,04.3,0,0,0,1,230,0,0,0,0
FMGS: 3971 : add Leg: R09,IF,GB09F,36.106847,-5.403039, ,0.0,0.0,1,1500,0,1,160,0,2,0
FMGS: 3971 : add Leg: R09,RF,GB096,36.150164,-5.378714,2,GB409,89.9,1.6,2,380,0,0,0,0,0,0
FMGS: 3971 : add Leg: R09,TF,RW09,36.150881,-5.358100,0, ,0.0,0.0,89.0,1.0,1,61,0,0,0,0,3,1
FMGS: 3971 : add Leg: R09,TF,GBM02,36.151669,-5.335536,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,0
FMGS: 3971 : add Leg: R09,TF,KUXOX,36.157414,-5.166344,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,0
FMGS: 3971 : add Leg: R09,TF,PIMOS,36.150361,-4.893472,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,1
FMGS: 3971 : add Leg: R09,DF,UPMUP,36.000000,-5.000000,2, ,0.0,0.0,1,4000,0,1,230,0,0,0
FMGS: 3971 : add Leg: R09,HM,UPMUP,36.000000,-5.000000,1, ,0.0,0.0,305.0,04.3,0,0,0,1,230,0,0,0,0
FMGS: 3972 : add Leg: R09,IF,GB09F,36.106847,-5.403039, ,0.0,0.0,1,1500,0,1,160,0,2,0
FMGS: 3972 : add Leg: R09,RF,GB096,36.150164,-5.378714,2,GB409,89.9,1.6,2,380,0,0,0,0,0,0
FMGS: 3972 : add Leg: R09,TF,RW09,36.150881,-5.358100,0, ,0.0,0.0,89.0,1.0,1,61,0,0,0,0,3,1
FMGS: 3972 : add Leg: R09,TF,GBM02,36.151669,-5.335536,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,0
FMGS: 3972 : add Leg: R09,TF,KUXOX,36.157414,-5.166344,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,0
FMGS: 3972 : add Leg: R09,TF,PIMOS,36.150361,-4.893472,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,1
FMGS: 3972 : add Leg: R09,DF,UPMUP,36.000000,-5.000000,2, ,0.0,0.0,1,4000,0,1,230,0,0,0
FMGS: 3972 : add Leg: R09,HM,UPMUP,36.000000,-5.000000,1, ,0.0,0.0,305.0,04.3,0,0,0,1,230,0,0,0,0
FMGS: 3974 : ICAO-format plan export to Dataref: LSGG SID DEPUL UY305 LSE UY305 RUSIT UY305 ESIDA UY305 LERGA UN869 MOKDI UN869 MINSO UN869 ROMAK UN869 NASEP UN869 NARAK UN869 AGN UN869 MAQAB UN869 TIVLI UN869 XOMBO UN869 ELSAP UN869 ZAR UN869 EXEMU UN869 PISUS UN869 EDIMU UN869 ADUXO UN869 NUSGO UN869 OBIBO UN869 NASOS UN869 ANZAN UN869 BLN UN869 MGA UN869 PIMOS DCT GB270 DCT GB272 DCT KUXOX DCT GB276 STAR LXGB
FMGS: 4004 : ICAO-format plan export to Dataref: LSGG SID DEPUL UY305 LSE UY305 RUSIT UY305 ESIDA UY305 LERGA UN869 MOKDI UN869 MINSO UN869 ROMAK UN869 NASEP UN869 NARAK UN869 AGN UN869 MAQAB UN869 TIVLI UN869 XOMBO UN869 ELSAP UN869 ZAR UN869 EXEMU UN869 PISUS UN869 EDIMU UN869 ADUXO UN869 NUSGO UN869 OBIBO UN869 NASOS UN869 ANZAN UN869 BLN UN869 MGA UN869 PIMOS STAR LXGB
FMGS: 4044 : ICAO-format plan export to Dataref: LSGG SID DEPUL UY305 LSE UY305 RUSIT UY305 ESIDA UY305 LERGA UN869 MOKDI UN869 MINSO UN869 ROMAK UN869 NASEP UN869 NARAK UN869 AGN UN869 MAQAB UN869 TIVLI UN869 XOMBO UN869 ELSAP UN869 ZAR UN869 EXEMU UN869 PISUS UN869 EDIMU UN869 ADUXO UN869 NUSGO UN869 OBIBO UN869 NASOS UN869 ANZAN UN869 BLN UN869 MGA UN869 PIMOS DCT BUGOV DCT GB092 DCT GB094 STAR LXGB
[JD320 INFO]: [LUA]: "module"    AP diseng. (SS roll reason)
FMGS: 4083 : ICAO-format plan export to Dataref: LSGG SID DEPUL UY305 LSE UY305 RUSIT UY305 ESIDA UY305 LERGA UN869 MOKDI UN869 MINSO UN869 ROMAK UN869 NASEP DCT T-P UN869 AGN UN869 MAQAB UN869 TIVLI UN869 XOMBO UN869 ELSAP UN869 ZAR UN869 EXEMU UN869 PISUS UN869 EDIMU UN869 ADUXO UN869 NUSGO UN869 OBIBO UN869 NASOS UN869 ANZAN UN869 BLN UN869 MGA UN869 PIMOS DCT BUGOV DCT GB092 DCT GB094 STAR LXGB
1:12:50.892 I/SCN: DSF load time: 60178 for file Custom Scenery/Global Airports/Earth nav data/+40-010/+45-001.dsf (0 tris, 0 skipped for 0.0 m^2)
1:12:50.947 I/SCN: DSF load time: 53528 for file Custom Scenery/Forests_Europe/Earth nav data/+40-010/+45-001.dsf (0 tris, 0 skipped for 0.0 m^2)
1:12:52.194 I/SCN: DSF load time: 1433780 for file Custom Scenery/LFBP - Pau Uzein/Earth nav data/+40-010/+43-001.dsf (0 tris, 0 skipped for 0.0 m^2)
1:12:52.591 I/SCN: DSF load time: 392738 for file Custom Scenery/Global Airports/Earth nav data/+40-010/+43-001.dsf (0 tris, 0 skipped for 0.0 m^2)
1:12:52.758 I/SCN: DSF load time: 167568 for file Custom Scenery/Forests_Europe/Earth nav data/+40-010/+43-001.dsf (0 tris, 0 skipped for 0.0 m^2)
1:12:53.331 I/SCN: DSF load time: 541292 for file D:\Ortho4XP\Ortho4XP\yOrtho4XP_Overlays/Earth nav data/+40-010/+43-001.dsf (0 tris, 0 skipped for 0.0 m^2)
1:12:55.732 I/SCN: DSF load time: 2344608 for file Custom Scenery/zOrtho4XP_+43-001/Earth nav data/+40-010/+43-001.dsf (702021 tris, 49 skipped for -30.0 m^2)
1:12:58.324 I/SCN: DSF load time: 7342134 for file E:\zzz_hd_global_scenery4/Earth nav data/+40-010/+45-001.dsf (1347227 tris, 94 skipped for -119.2 m^2)
1:13:02.738 I/SCN: DSF load time: 1206440 for file Custom Scenery/LFBD Bordeaux - Beta 0.7/Earth nav data/+40-010/+44-001.dsf (0 tris, 0 skipped for 0.0 m^2)
1:13:02.738 I/SCN: DSF load time: 1056 for file Custom Scenery/LFCS_Scenery_Pack/Earth nav data/+40-010/+44-001.dsf (0 tris, 0 skipped for 0.0 m^2)
1:13:02.805 I/SCN: DSF load time: 39290 for file Custom Scenery/Global Airports/Earth nav data/+40-010/+44-001.dsf (0 tris, 0 skipped for 0.0 m^2)
1:13:02.834 I/SCN: DSF load time: 49098 for file Custom Scenery/Forests_Europe/Earth nav data/+40-010/+44-001.dsf (0 tris, 0 skipped for 0.0 m^2)
1:13:03.474 I/SCN: DSF load time: 623832 for file D:\Ortho4XP\Ortho4XP\yOrtho4XP_Overlays/Earth nav data/+40-010/+44-001.dsf (0 tris, 0 skipped for 0.0 m^2)
1:13:04.836 I/SCN: DSF load time: 1245044 for file Custom Scenery/zOrtho4XP_+44-001/Earth nav data/+40-010/+44-001.dsf (364969 tris, 95 skipped for -24114.5 m^2)
Xchecklist: found C:\X-Plane 11\Aircraft\Extra Aircraft\320_JARDesign_361\clist.txt
alain.bo wrote:
schnappi wrote:
Here is a list of errors for the JD A320 v3.6RC1
1. I use the Thrustmaster T.16000M, and so far I have been able to adjust the spoilers with the Throttle (2). This is no longer possible with the V3.6RC1. I can only change the position of the spoiler armed to disarmed. I can adjust the spoilers with the mouse. Please correction.
Horst
I use the TWCS one for that but that doesn't change anything and I can set the spoilers with the dedicated commands as shown below:
http://jardesign.org/forum/img/m/4152/t/p1ehejlqnk1ei12k410c42jbamj3.png
Thank you for the tip, so far it has just worked differently.
JD A320
JD A330
58 (edited by Fab10 2020-09-14 12:44:25)
http://jardesign.org/forum/img/m/390/t/p1ei62kirbj33fm18rj6ce1m223.jpg
JD320XP1150_3620
JD320V3.6R2
Weather Radar shows strange lines (FSGRW, SMP/RWC).
That’s the P1 ND, radar switch set to 1.
If radar is switched to 2, then the ND is normal without those odd (route?) lines.
59
I do not understand what happend with this aircraft, The display for heading and spead/mach does not show any value, if I turn the knob this nothing happens! It has been much fun flying with your aircraft, but the fun is gone, since I do not understand this behavior!
60 (edited by huaguang16 2020-09-18 04:40:34)
Hello sir, great update on R2. I still find that the xplane will CTD when clicking on the ATIS panel (the small one on top of the FMC). It is quite useful for getting current weather info for the airport.
update: Just noticed this has been addressed in the release notes, my bad.
61
Hello Mr Romanov
I posted my list of noticeable bugs here (http://jardesign.org/forum/viewtopic.php?id=12013) but nothing was being replied to so I noticed more action on this part of the forum and so here it is.
Look forward to your response.
I have a stutter with both the A320 v3.5b2 and the v3.6r2 in the current XP11 v11.50r3, as shown in the video.
With other aircraft, e.g. Zibo B737-800X, the stuttering does not occur. What can that be?
https://www.youtube.com/watch?v=i4K5dD5x7uI
Thanks and Regards
JD A320
JD A330
ya need to make your video public brah so we can watch it
Thanks and Regards
64 (edited by hardfloor 2020-09-22 05:05:56)
Check out my stutter bug here https://www.twitch.tv/videos/748497076 Jump to 11mins:15sec in the stream and you'll see my stutter problem tongue
Thanks and Regards
Sorry, now I've set the video to "public".
JD A320
JD A330
No reply, complete silence of the developer.
Lots of bugs, no fixes.
XP 11.50 is final, so that's no longer the problem.
67
yeah thats quite odd and perfectly cyclical. Dare I ask you are running Vulkan or OGL?
68
I use Vulkan.
The same effect occurs with the A330 v4r2. As already described, this jerking or jumping does not occur with standard aircraft or the Zibo B737-800X.
JD A320
JD A330
I see. I had some poor performance with the JAR 320 R2, with the Fly With Lua engine. If you're running the Lua engine in your plugins try terminating that operation and see if you get an improvement. Seeing as other aircraft are running fine with your standard set up, there might be plugins in your standard set up which are not jiving with the JAR aircraft. Do a process of elimination by terminating the non essential plugins one by one.
schnappi wrote:
I use Vulkan.
bought the A320 yesterday
Worked so far I could test without problems .. good job
only one thing : the lower ECAM started suddenly to cycle thru all the pages
.. could not stop that
  i this a bug or one off Airbus hidden surprises ?
71 (edited by royaloak 2020-09-28 16:09:09)
New version JD320-V3 6R2
(1)How do you close the cockpit door? (I see the lock control on the lower pedestal but how do you close it?
(2) How do you stop the QNH indicator flashing when it passes transition altitude?  You can set 1013 Hpa manually but not with an "STD" instrument push.  Also, on the QNH adjust control there is an unnecessary tooltip which appears.
(3) In the previous models, a "hand" appeared on the Main Controls. (Speed and Heading) when you wished to change from automatic control to manual control.  On my first test flight I was unable to change from Auto to Manual, all the speeds were controlled by the flaps position and the heading by the flightplan.  This would have made ATC Vectoring impossible.
Thanks for the continued updates of this great model
72
Thanks and Regards
The error has been resolved, was due to a LUA script.
Many thanks for the help.
Greetings
Horst
JD A320
JD A330
73
1. Set the door lock to UNLOCK, then close the door with the mouse. Then set the door lock to LOCK.
2. The operation of the switches and knobs has changed slightly. To switch the QNH display to STD, press the rotary knob with the right mouse button.
3. Unfortunately, the hand symbol no longer exists. I thought that was very good. The functions are probably operated with the right or left mouse button as before, but here I still have to try.
JD A320
JD A330
74 (edited by royaloak 2020-09-29 16:44:05)
Thanks for the info.  I am loading up X-Plane 11.50 now and will give the aircraft another try.  Fortunately, I still have 320_JARDesign_11.50_352 which has all the "classic" features.
Edit :  You were correct, the right and left mouse buttons control the "Auto/Manual" switching.  So, all OK in that respect.  One thing I have noticed is that if you initially set the altitude at you cruising altitude, it will NOT follow the altitude restraints as per those included in the selected STAR, although these are noted in the flightplan on the MCDU.     If I am right, the previous models did follow these restraints automatically?
Just noticed, from very first post in this thread, "+ FCU knobs manipulator reworked (usage with mouse right/left buttons & mousewheel)"
cool. yeah sometimes some background lua script can be fighting with another and sometimes the lua engine isnt clever enough to automatically send the non essential script to quarantine. Glad you found the issue.
Thanks and Regards
Greetings
Horst
