1 (edited by Coverdale 2020-08-17 16:22:51)
Topic: X-Life problem at SBRJ
After I start X-Life, the planes take the taxi routes to the runway. Once there, wait for planes to arrive. After clearance, the first aircraft drives up and then stops again in the middle of the runway. After another release, the aircraft takes off, but does not take off and gets stuck at the end of the runway. There it only runs small loops and all air traffic is no longer continued. There is no longer any clearance for the next aircraft. So there is only the option to end X-Life (see video).
Does anyone here have the same problem or has a solution to the problem?
Greetings, Coverdale
Re: X-Life problem at SBRJ
Same kind of dead-lock in YPDN (Darwin). Per the tower tab in X-Life, I saw that the aircraft in second takeoff position on the taxiway (before threshold area) had the clearance. However, having an aircraft in from of her, no ability to proceed to the runway.
So those deadlocks can probably appear at any airport. It could be a flaw in the AI.
BTW, made minor changes to SBRJ: removed gates occupied by static aircraft (Air Canada), removed all "NONAME" and realigned many nodes. Will post.
