Topic: Ground Handling Deluxe can not see nothing
Ground Handling Deluxe i installed in my plugin folder of XPlane1.50 i acctivate the product but when i start to view nothing happend, nothing see around my plane.
JARDesign Group Board → General Discussion → Ground Handling Deluxe can not see nothing
When you have started an aircraft go to plugins menu at the top of the screen, then click on Ground handling … there you can find all possibilities …
I have the same issue and did all that even using the 747 like the manual said and nothing shows, I can see the diagram showing all the vechilcles around the plane but nothing to actually see, any ideas?
