Topic: First Officer Not Visible
I have sent several support tickets on this with no reply. I have installed the version on the Sticky Note for A310 V1.4 but co-pilot still not visible. Checklists work fine and product would be perfect if visuals worked.
Re: First Officer Not Visible
You may Uninstall it using MENU, reload aircraft, Setup it using menu, reload aircraft. Sure, you may contact skype j.a.romanov for direct help.
I did try that but will do it one more time. I am using three monitors. Does that affect things?
I did what you suggested and now I see the woman FO but have lost any sound. No readback. Speech engine is working on other programmes so that's not the issue.
Working now thanks and good programme finally. For reference I needed to install all files in the directory of the aircraft below the main plugins. Instructions on this need to be clearer I think.
Andy
