Topic: Trafic in EDDM ?
Hi guys,
I have the beautiful EDDM from shortfinal but when I activated xlife, unfortunately, this big airports seems still relatively empty because all the gates are not full.
Do you know if an xlife update exists ?
Thanks a lot for your help
Re: Trafic in EDDM ?
Have you set the parameters beyond 50?
Because the airport have all gate ready
I make a little update try if you see changement tell us.
https://i.ibb.co/SB42Hx4/Cessna-172-SP-2020-06-01-17-14-44.png
https://i.ibb.co/4Mp2WC2/Cessna-172-SP-2020-06-01-17-15-05.png
https://i.ibb.co/Kx3RmMn/Cessna-172-SP-2020-06-01-17-18-24.png
https://i.ibb.co/cYqzKwH/Cessna-172-SP-2020-06-01-17-18-33.png
https://i.ibb.co/WBXmdMz/Cessna-172-SP-2020-06-01-17-19-00.png
https://i.ibb.co/tqHPQjN/Cessna-172-SP-2020-06-01-17-19-23.png
Thanks so much smile) That's very nice. I will try and tell you if all is ok
Hi dzscenery,
I checked with your file.
It's fantastic. I love how the airport is full with airplanes wink
Thanks again
Have a good day
Alexandre
