1 (edited by JNissen 2020-05-05 10:14:28)
Topic: I seem to have an issue with incoming flights at VHHX
SOLVED
Dear all
I have optimized the taxi routes for VHHX, but have encountered a problem. Monitoring the traffic moving along seemingly without any hiccups for hours (on a monitor beside my work PC...), then suddenly one plane "abort" takeoff at the end of runway 31. Sometimes this happens after 10-15 minutes after startup of x-life and other times it happens after hours.
I have tried to draw a conclusion, but there is no denominator - I thought. But then I saw a pattern. It happened even when no planes are in the vicinity of the runway. Not on ground at least, but if there is an approaching plane inside the 3 nm distance and a plane taking off is at the end of runway 31 then it happens every time!
Now the question. Can I change this somehow (in the apt file or...) or is it a clinch in the x-life code.
I cannot rule out it's my "drawing" skills that have caused this behavior, but that don't explain why it can run for hours without any hiccups.
Jan
