Topic: Ground handling shows default livery
Hello Guys.
I have downloaded some liverys making by other members. For example Emirates or Skychefs.When i want to load it it only shows the default livery . Can anybody help me ?
Greets
Re: Ground handling shows default livery
Got the same Problem since updating to the 11.50 Version liveries are only working with the Default liveries that came with gnd so for example S7 if you want to use other custom liveries you have to copy and replace the files into such an Folder and dont rename it. thats sadly the only way at the Moment and i hope jar design will fix it in the near future
found a solution
download the ghd paintkit from simliveries and put it into the liverie folder
