Topic: FMCar v2.8 For Win10/MACOS (for X-Plane 11.50+)
FMCar v2.8 version.
What New version 2.8:
+ CTD when calling from X-Life fixed
+ a lot of airports add
Whats New version 2.7:
+ reworked to be compatible with X-Plane 11.50
+ X-Plane 11.41 compatible
Download here:
http://www.jardesign.org/fmcar/download … 201021.zip
If something going wrong with this beta (you will test beta FMCar with beta X-Plane) - please post info here or contact me skype j.a.romanov for direct help (preferable)
Re: FMCar v2.8 For Win10/MACOS (for X-Plane 11.50+)
res
I would like to use FMCar with my x-plane11. Is ist a feeware version or a payware. If it is a payware where can I by it?
http://jardesign.org/followme-car-for-x-plane-10/
5 (edited by vei30 2020-06-05 04:23:45)
FMCar v2.7 beta version. It will be in beta-mode until X-Plane 11.50 release come.
Whats New:
Download here:
http://www.jardesign.org/fmcar/download/FMCar_v2.7.zip
I don't know why but version 2.7 doesn't appear in the plugin menu. The simulator does not see this plugin
6 (edited by vei30 2020-06-05 09:55:27)
Зарегистрировался, но 2.7 вообще отсутствует  в плагинах X-{lane 11.50 Хотя папка есть. В чем проблема?
вООБЩЕ ЗДЕСЬ КТО НИБУДЬ БЫВАЕТ?
If I select from X-life follow me car to take me to gate, followme cars blinking until FM Car find on what airport I am landing. FM car width taxi map usualy take to much time to identified airport on plane landing. Many times I parking the plane and then FM car show map - but there is no need to show so late.
Can you somtehing make with try to enlarge map, becouse in big airports when I realy need map, can't see named taxiways?
Beta version for different windows are i am trying to ready. I know this is the only good way to tell you that i am making such versions which help you to promote my college-paper.org reviews working. I also want to check different style where i must have to show others my working.
JAR
Could you comment this my posts. Are you still working on this project?
When better pushback tug has departed and taxi granted by X Life ATC requesting FM Car via ATC crashses X plane.
xplane 11.52r1 crashes without a sound when trying to appear on OJAI (on macOS 11.2.3) ... the reason was the FM.xpl (followme car by JAR). Deleting plugins/FM/Airports/OJAI.xlf does nothing, the file is apparently reloaded from the JAR server when the plugin is started.
I deleted OJAI.xlf and the corresponding line in plugins/FM/Airports/airports.txt, no success. Both is freshly downloaded when  xplane start. I copied OLBA.xlf over OJAI.xlf, this helped. Even I could use FM at OJAI correctly. Very strange !!!
Hi there,  I purchased follow me last night.  I'm using windows 10 and running x-plane 11.50 I imported "FM into my plugins folder and ran the x-plane 11 program which did startup the first time and inserted my serial number and email account, right after that my x-plane crashed, and wasn't able to start x-plane until I removed the FM folder. I'm really looking forward to using the plugin is there a workaround for the file error is win.xpl   Thank you in advance for your help have a wonderful weekend
Melissa
I bought a plugin on Steam, after reinstalling the system, it asks for a registration number, what should I do?
Use registration key
It must be in email
Can You please answer me afer one year of my question ?
If we will decide to save FMCar for XP12 - it must be reworked. I am agree - for actual monitors this is very small size.
I bought the product from store.x-plane.org and didn't receive the serial number and the email I sent them was rejected
http://jardesign.org/forum/img/m/13023/t/p1fqg1dgt1dqi1htjkhf1s9r1leq3.png
http://jardesign.org/forum/img/m/13023/t/p1fqg1dmc21qm17o11u6q395at37.png
http://jardesign.org/forum/img/m/13023/t/p1fqg1g753vjcfkmqbl1at2nag9.png
About order 1583100 - please contact shop support to know your order details. Sure tech-support have no access to your personal data (include your serial key) in this shop.
24 (edited by slicker55 2022-07-13 22:26:23)
I have a question in relation to my X-Plane log file which says:
XLF file exist: D:\X-Plane 11\Resources\plugins\FM\Airports/LOWW.xlf
DAT file not exist: D:\X-Plane 11\Resources\plugins\FM\Airports/LOWW.dat
I am using Windows 10, XP 11.55 (Vulkan) with Gaya Simulations LOWW payware scenery and FMCar 2.8
I have checked the file location and can physically see the DAT file referenced in the X-Plane log.
Any idea what is going on here?
If you have xlf file, you dont need DAT file.
