Topic: GHD Set for new ssg 747 V2 control widget
Just purchased GHD v2 2 days ago and have a problem with control widget. When I go to plugin and open control widget, outline of plane is missing and only a few items show on screen. I followed instructions and loaded default 747 as required. When I load the 747 V2 I get this problem. It worked fine with the default 747.
I know I am doing something wrong, so any help would would be great.
Cheers
2 (edited by jcdp 2020-03-31 14:02:44)
Re: GHD Set for new ssg 747 V2 control widget
Cheers
May be you have not the right set . Try the one attached .(to be installed in  …/plugins/ground handling/sets/custom )
