Re: XP11.50 JD330 v.4.1
Another Thing additional to the mentioned above is the Support of the Thrustmaster TCA by A330 like it is partially done in A320neo. Could we expect that Support in the near Future?
JARDesign Group Board → Downloads, Updates. → XP11.50 JD330 v.4.1
As some other people, I am having the weather problem and my last flight was rejected by IVAO due to "no real weather". I did the same flight today with A332 after discussions with IVAO rep and I observed that as soon as you take off winds show 002-004/01-02 knots until the flight finishes. I hope this is going to be solved in a short time. I was flying the fpsboost version of 4.1r1. See attached for approach instances against METAR showing winds 040/20.
Weather problem could be identified on a Skype call to JAR and after that could also be fixed. So in near future there will be an update that will solve the issue.
I think the weather problem has something to do with the turbulence setting. I had problems with weather in version 4.0.5. Went into the MDCU and switched off turbulence. This solved the problem and the plane still experienced turbulence. The most recent version does not have the turbulence on/off option. I tried turning on or off options in the MDCU to no avail. I submitted a ticket but JAR was unaware of this issue. I know that several people are having issues with no weather showing up.
Good Morning JAR Design Team,
it's very nice that you try to fix the problem with the "Real Weather", but when I had look at the forum this morning and saw this:
v.4.1R2:
+ "Real Weather" issue fixed
+ TCA Quadrant usage issue fixed
then at the first moment I was very happy and thought: Wow they fixed it, but as soon as I cklicked on the download link and after that opened the folder I found V.4.1R1 again.
For the future please try to put the download link first and then update the information.
I hope to get the new link this weekend because it sucks to have a paid airplane which I can´t use for online flying.
@florian.esslinger: Definitely. There's no R2 file for download...
Hi, Check "version.txt" in J330 aircaft folder , mine is : "JD330-V4.0R2" .
PS
In fact it exists "JD330-V4.1R2" at :
" http://jardesign.org/forum/viewtopic.php?id=11833 "
Hi, with R2 i cant arm the speedbrakes...
I must say that with 4.1R2 , when I try to get weather info, after a while, aircraft is crashing (I see that on outside view )
aircraft in flames ... :-(
So no idea (not yet) about speedbrakes ...
I just set the TCA quadrant and the sidestick and throttles ok, but the igniters and engines mode don't work. Can someone give me the key of what is or where to find the position TCA_MasterSwitch1ON to assign from the jd command ¨TCA_MasterSwitch1ON¨?.
Thank you in advance for your help
@Devis80, you have to shut off the spoilers axis in the settings menu to get the speed brakes to arm with a joystick command. Hope that helps!
From the beginning and with the update to 11.5 as well, I have an initial error of the position of the pilot in the cockpit. It's to the right of the correct riding position and the seat back a little. It is only solved if I incorporate the x-camera plugin, but I usually use head traker.
Would someone tell me how to solve the issue of the position so that it is centered on the piloting?
Thank you very much in advance
Open XPuipc plugin and enter the IP address of your computer in the XPUIPC.ini file.
Hello
Where the weather meteo come from?
My xuipc.ini is with the good IP adresse but i have the message and
Capecod
Hello.
As Mr Romanov explain i 've tried to set the tca quadrant on the mcdu, but when i set the TCA on "on" it doesn't want to stay, and it returns on "off" automatically.
Have you got an issue, please.
Thank you for your feedback.
jmeleanor.
Добрый день. Хочу сообщить о имеющихся на сегодняшний день проблемах с самолётом. Версия V4.1R2.
1. Самолёт после набора эшелона, не переводит двигатели в режим CRZ и продолжает лететь в CLB, до посадки. Весь полет на MD отображается индикатор T/C (рис 1)
2. На крайней версии не работает BSS Sound Pack
3. Попытка загрузить METAR через бортовую систему приводит к зависанию/вылету симулятора.
4. Отключенные топливные насосы не препятствуют запуску двигателей.
И еще хочу спросить, планируется проработка привязки функций к клавишам/кнопкам контроллера?
Рассчитываю на обратную связь, спасибо.
Hi J.A.Romanov
The Engines in V4.1 RC2 cannot be switched off by the engine-master. Are you serious?
Also: I am doing an approach. Before the approach begins I have reduced the IAS to 220 knots in the MCDU. After "Approach phase is activated" the limit for the waypoint is over, and my aircraft speeds up like in TO/GA-mode.
I think, the A330 V4.05 is even better developed. Why are you doing that? Why is the plane getting worse and worse from update to update? Are you updating an old file with bugs?
That happens to me too. But Mr Romanov does not want to know about these problems.
Anyway.....
Hi J.A.Romanov
The Engines in V4.1 RC2 cannot be switched off by the engine-master. Are you serious?Also: I am doing an approach. Before the approach begins I have reduced the IAS to 220 knots in the MCDU. After "Approach phase is activated" the limit for the waypoint is over, and my aircraft speeds up like in TO/GA-mode.
***I have the exact same problem and a lot of other ones as well. Not sure if this aircraft was tested properly before release but I am furious that I have wasted $70.00 on this. I dont even know where to list all of the bugs that I have found on this aircraft or if anyone will even care. Just to point out that I fly for a major airline in Canada
Hello
This plane is uncontrollable at high altitude and with real weather ... Oblige to deactivate the real weather in order to be able to pilot this plane ...
And yet it is stipulated
v.4.1R2:
+ Fixed "Real Weather" problem
+ Fixed issue with TCA Quadrant usage
There is nothing more to understand
Good flight
SIM crashed - fresh install
[JD330 INFO]: [LUA]:
[JD330 INFO]: [LUA]: >>> zulu 14:33:16
[JD330 INFO]: [LUA]: baro alt=3911 / rad alt=3710
[JD330 INFO]: [LUA]: air spd=243 / gnd spd=233 / mach=0.39
[JD330 INFO]: [LUA]: GW=229718 / FOB=64524 / CG=28
[JD330 INFO]: [LUA]: thr mode = MAN THR
1:04:32.102 xPilot/XPMP2 DEBUG Aircraft.cpp:543/DestroyInstances: Aircraft 0x000090: Instance destroyed
1:04:35.615 xPilot/XPMP2 DEBUG CSLModels.cpp:249/Unload: Object __Bluebell_Airbus/A321_BAW / C:\X-Plane 11\Resources\plugins\xPilot\Resources\CSL/BB_Airbus/A321/A321_BAW.obj unloaded
1:04:52.415 xPilot/XPMP2 DEBUG Aircraft.cpp:543/DestroyInstances: Aircraft 0x000038: Instance destroyed
1:04:53.409 xPilot/XPMP2 DEBUG Aircraft.cpp:543/DestroyInstances: Aircraft 0x000071: Instance destroyed
1:05:14.489 xPilot/XPMP2 DEBUG Aircraft.cpp:543/DestroyInstances: Aircraft 0x00007A: Instance destroyed
1:05:37.001 xPilot/XPMP2 DEBUG Aircraft.cpp:543/DestroyInstances: Aircraft 0x00008F: Instance destroyed
1:06:05.129 xPilot/XPMP2 DEBUG Aircraft.cpp:543/DestroyInstances: Aircraft 0x000043: Instance destroyed
1:06:12.442 I/ATC: Airport flow changed at EGDL!
CurFlow: AUTOGEN: West NewFlow: AUTOGEN: South
1:06:12.442 I/ATC: Changing EGDL CabState from 0 to 1
1:06:12.442 I/ATC: All departures are done at EGDL. Advancing...
1:06:12.442 I/ATC: Changing EGDL CabState from 1 to 2
1:06:12.442 I/ATC: All arrivals are done at EGDL. Advancing...
1:06:12.442 I/ATC: Changing EGDL CabState from 2 to 0
1:06:13.045 xPilot/XPMP2 DEBUG Aircraft.cpp:543/DestroyInstances: Aircraft 0x000015: Instance destroyed
1:06:35.628 xPilot/XPMP2 DEBUG CSLModels.cpp:249/Unload: Object __Bluebell_Airbus/A319_BAW / C:\X-Plane 11\Resources\plugins\xPilot\Resources\CSL/BB_Airbus/A319/A319_BAW.obj unloaded
1:06:46.773 xPilot/XPMP2 DEBUG CSLModels.cpp:229/Load: Async load starting for __Bluebell_Boeing/B738_ORB from C:\X-Plane 11\Resources\plugins\xPilot\Resources\CSL/BB_Boeing/B738/B738_ORB.obj
1:06:46.773 xPilot/XPMP2 DEBUG CSLModels.cpp:286/XPObjLoadedCB: Async load succeeded for __Bluebell_Boeing/B738_ORB from C:\X-Plane 11\Resources\plugins\xPilot\Resources\CSL/BB_Boeing/B738/B738_ORB.obj
1:06:46.797 xPilot/XPMP2 DEBUG Aircraft.cpp:524/CreateInstances: Aircraft 0x000091: Instance created
1:06:59.136 I/SCN: DSF load time: 7719 for file Custom Scenery/Global Airports/Earth nav data/+50-010/+50-003.dsf (0 tris, 0 skipped for 0.0 m^2)
1:06:59.861 I/SCN: DSF load time: 713571 for file Custom Scenery/Orbx_A_GB_South_TrueEarth_Custom/Earth nav data/+50-010/+50-003.dsf (0 tris, 0 skipped for 0.0 m^2)
1:06:59.861 I/SCN: DSF load time: 733294 for file Custom Scenery/Global Airports/Earth nav data/+50-010/+52-003.dsf (0 tris, 0 skipped for 0.0 m^2)
1:07:01.835 I/SCN: DSF load time: 1971837 for file Custom Scenery/Orbx_A_GB_South_TrueEarth_Custom/Earth nav data/+50-010/+52-003.dsf (0 tris, 0 skipped for 0.0 m^2)
1:07:02.082 I/SCN: DSF load time: 2233636 for file Custom Scenery/Orbx_B_GB_South_TrueEarth_Overlay/Earth nav data/+50-010/+50-003.dsf (0 tris, 0 skipped for 0.0 m^2)
1:07:02.354 xPilot/XPMP2 DEBUG CSLModels.cpp:229/Load: Async load starting for __Bluebell_Boeing/B77W_THY from C:\X-Plane 11\Resources\plugins\xPilot\Resources\CSL/BB_Boeing/B77W/B77W_THY.obj
1:07:02.354 xPilot/XPMP2 DEBUG CSLModels.cpp:286/XPObjLoadedCB: Async load succeeded for __Bluebell_Boeing/B77W_THY from C:\X-Plane 11\Resources\plugins\xPilot\Resources\CSL/BB_Boeing/B77W/B77W_THY.obj
1:07:02.379 xPilot/XPMP2 DEBUG Aircraft.cpp:524/CreateInstances: Aircraft 0x000092: Instance created
1:07:05.413 I/SCN: DSF load time: 3315874 for file Custom Scenery/Orbx_C_GB_South_TrueEarth_Orthos/Earth nav data/+50-010/+50-003.dsf (586249 tris, 47 skipped for -6.2 m^2)
1:07:09.490 I/SCN: DSF load time: 7656314 for file Custom Scenery/Orbx_B_GB_South_TrueEarth_Overlay/Earth nav data/+50-010/+52-003.dsf (0 tris, 0 skipped for 0.0 m^2)
1:07:10.422 xPilot/XPMP2 DEBUG Aircraft.cpp:524/CreateInstances: Aircraft 0x000093: Instance created
FMGS: 3913 : ICAO-format plan export to Dataref: EGKK SID DCT T-P N63 SAM N19 NULGU N19 ADKIK N19 KOXOD N19 JOZMA N19 SOPTU N19 UNPUP N19 GAPLI DCT OMOKO DCT 4520N DCT INBUL DCT 3040N DCT 2350N DCT DRDGE DCT FOF UA324 BNE STAR TLPL
I have just downloaded and installed it into XP11.51 then when i entered the activation code from my original X-Plane org store purchase it says it is invalid when i copy and paste it in.
I did make sure i entered the correct code.
Any ideas what could be wrong.
JAR should work hard on MCDU, should work hard on Autopilot System, should work hard on ECAM Displays; they are important even we can see they doesn't close reality that is too far... it is version 4+ and still too far from reality... I love Airbus A330 thats why i bought this plane from JARDesign but JAR still should work hard on it, PLEASE JAR GIVE US AN A330 LIKE REAL, I KNOW YOU CAN DO IT...
Bingo! only update from long time ago regarded weather that doesnt update. Nothing more everything around plane.. i can't use this bird for all this reason. its unacceptable
THIS BLOODY AIRCRAFT ALONE WITH THE COPILOT INCLUDING THE A320 doesnt work.
The A320 HAS NO SOUND AT ALL.
Now this BS. The A330 copilot GETS STUCK DURING THE VERY FIRST PROCEDURE. LINDA THAT IS. IF I PROCEDE TO FORCE HER TO DO THE SAME PROCEDURE AGAIN SHE GETS STUCK ASKING ME OVER AND OVER AND OVER THE SAME BLOODY THING.
SO ALL IN ALL TWO AIRCRAFTS DONT WORK NEITHER DOES THE COPILOT.
I TOLD YOU ALREADY, THIS NEEDS FIXING AND I WILL CHARGE BACK $100 WORTH OF PROGRAMS BUT YOU DONT WANT TO LISTEN. iM NOT GOING TO TELL YOU AGAIN.
RESOLVE THE BUGS OR GET CHARGEBACKS THOUGH PAYPAL. AND GET THE HELL OUT OF BUSINESS. YOUR PROGRAMS DONT WORK. YOU CALL THIS A BETA VERSION? WHEN WAS THE LAST TIME YOU REPLIED IN THIS THREAD TO FIND OUT WHAT ISSUES PEOPLE ARE HAVING?
