176 (edited by rjarret 2020-09-12 03:18:15)
Re: XP11.50 JD330 v.4.1
How can I download the latest release RC4.0.5? The link on the first page of this threads downloads JD330-V4.0R1 sad
177
JD330-V4.0R1 is actual and more fresh
178
When I load into the plane and activate it, I am not able to pull up the toolbar with the plugins and stuff on the top of my screen. So I cant reload the plane. If someone could help that would be awesome smile
179
Today I did een long haul and after a little bit over 7 hours inflight I was putting in the arrival and just after I did that I had a Crash to desktop.
Ik looked in my log and this was what I say
FMGS: 27417 : add Leg: I26L,IF,CF26L,51.177222,0.022158,IWW,77.6,9.2,1,2000,0,0,0,0,0,0
FMGS: 27417 : add Leg: I26L,CF,FF26L,51.170175,-0.029606,0,IWW,77.6,7.2,258.0,2.0,1,2000,0,0,0,0,2,0
FMGS: 27417 : add Leg: I26L,CF,RW26L,51.150672,-0.171944,0,IWW,77.6,1.7,258.0,5.5,1,248,0,0,0,0,3,0
FMGS: 27417 : add Leg: I26L,CA,0,258.0,2,2000,0,0,0,0,0,0
FMGS: 27417 : add Leg: I26L,VM,0,0,0,178.0,1,3000,0,0,0,0,0,0
FMGS: 27423 : add Leg: WILO3B,IF,KIDLI,51.771389,-1.361389, ,0.0,0.0,1,15000,0,0,0,0,0,0
FMGS: 27423 : add Leg: WILO3B,TF,MID,51.053889,-0.625000,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,0
FMGS: 27423 : add Leg: WILO3B,TF,D116E,51.017339,-0.506392,0, ,0.0,0.0,0.0,0.0,0,0,0,1,250,0,0,0
FMGS: 27423 : add Leg: WILO3B,TF,HOLLY,50.886667,-0.095000,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,1
FMGS: 27423 : add Leg: WILO3B,CF,WILLO,50.985000,-0.191667,1,MID,104.0,16.9,284.0,5.0,0,0,0,0,0,0,0,0
FMGS: 27423 : add Leg: WILLO,IF,WILLO,50.985000,-0.191667, ,0.0,0.0,1,4000,0,0,0,0,0,0
FMGS: 27423 : add Leg: WILLO,CF,D116V,50.901253,-0.097633,1,MID,114.4,22.0,104.0,5.0,0,0,0,0,0,0,0,1
FMGS: 27423 : add Leg: WILLO,CF,MAY,51.017222,0.116111,0,MAY,0.0,0.0,42.0,10.0,1,4000,0,0,0,0,0,0
FMGS: 27423 : add Leg: WILLO,FD,MAY,51.017222,0.116111,0,MAY,0.0,8.5,3.0,8.5,1,2000,0,0,0,0,0,0
FMGS: 27423 : add Leg: WILLO,CF,CF26L,51.177222,0.022158,1,IWW,77.6,9.2,258.0,2.0,1,2000,0,0,0,0,0,0
FMGS: 27423 : add Leg: I26L,IF,CF26L,51.177222,0.022158,IWW,77.6,9.2,1,2000,0,0,0,0,0,0
FMGS: 27423 : add Leg: I26L,CF,FF26L,51.170175,-0.029606,0,IWW,77.6,7.2,258.0,2.0,1,2000,0,0,0,0,2,0
FMGS: 27423 : add Leg: I26L,CF,RW26L,51.150672,-0.171944,0,IWW,77.6,1.7,258.0,5.5,1,248,0,0,0,0,3,0
FMGS: 27423 : add Leg: I26L,CA,0,258.0,2,2000,0,0,0,0,0,0
FMGS: 27423 : add Leg: I26L,VM,0,0,0,178.0,1,3000,0,0,0,0,0,0
FMGS: 27427 : add Leg: WILO3B,IF,KIDLI,51.771389,-1.361389, ,0.0,0.0,1,15000,0,0,0,0,0,0
FMGS: 27427 : add Leg: WILO3B,TF,MID,51.053889,-0.625000,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,0
FMGS: 27427 : add Leg: WILO3B,TF,D116E,51.017339,-0.506392,0, ,0.0,0.0,0.0,0.0,0,0,0,1,250,0,0,0
FMGS: 27427 : add Leg: WILO3B,TF,HOLLY,50.886667,-0.095000,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,1
FMGS: 27427 : add Leg: WILO3B,CF,WILLO,50.985000,-0.191667,1,MID,104.0,16.9,284.0,5.0,0,0,0,0,0,0,0,0
FMGS: 27427 : add Leg: WILLO,IF,WILLO,50.985000,-0.191667, ,0.0,0.0,1,4000,0,0,0,0,0,0
FMGS: 27427 : add Leg: WILLO,CF,D116V,50.901253,-0.097633,1,MID,114.4,22.0,104.0,5.0,0,0,0,0,0,0,0,1
FMGS: 27427 : add Leg: WILLO,CF,MAY,51.017222,0.116111,0,MAY,0.0,0.0,42.0,10.0,1,4000,0,0,0,0,0,0
FMGS: 27427 : add Leg: WILLO,FD,MAY,51.017222,0.116111,0,MAY,0.0,8.5,3.0,8.5,1,2000,0,0,0,0,0,0
FMGS: 27427 : add Leg: WILLO,CF,CF26L,51.177222,0.022158,1,IWW,77.6,9.2,258.0,2.0,1,2000,0,0,0,0,0,0
FMGS: 27427 : add Leg: I26L,IF,CF26L,51.177222,0.022158,IWW,77.6,9.2,1,2000,0,0,0,0,0,0
FMGS: 27427 : add Leg: I26L,CF,FF26L,51.170175,-0.029606,0,IWW,77.6,7.2,258.0,2.0,1,2000,0,0,0,0,2,0
FMGS: 27427 : add Leg: I26L,CF,RW26L,51.150672,-0.171944,0,IWW,77.6,1.7,258.0,5.5,1,248,0,0,0,0,3,0
FMGS: 27427 : add Leg: I26L,CA,0,258.0,2,2000,0,0,0,0,0,0
FMGS: 27427 : add Leg: I26L,VM,0,0,0,178.0,1,3000,0,0,0,0,0,0
FMGS: 27430 : ICAO-format plan export to Dataref: KBNA SID OLSIE DCT IIU DCT KC69U DCT SYR DCT CABCI DCT MIILS N329B ELSIR DCT NETKI DCT LIFFY UL975 IDEXA UL975 GINIS UL975 NATKO UL975 LYNAS UL975 ROLEX UL975 MALUD L15 EPOXI L15 AMPIT L15 RISLA L15 KEPAD L151 TELBA L151 VIDOK L151 UMLUX L151 PEPUL L151 DISIT L151 TUBSU L151 NANUM L151 NEDEX L151 KIDLI STAR EGKK
Is this something of X-plane itself or was there something going wrong with de A330. I find it always difficult to read those logs.
I am using the latest version of the A330 and X-plane 11.50.
Thank you in advance.
Cor
180 (edited by florian.esslinger 2020-09-14 03:57:50)
Hello everybody,
since version 4.0R2 and 11.50 of X-Plane I have the following problem. When I start a new flight with the A330 and I loaded the live weather before I have no more live weather when I'm in the cockpit. If I reload only the weather it looks good for the moment but as soon as I'm airborne the problem is back again. No clouds, no wind, nothing. I had this problem with an older version too but I don't know what fixed this problem in the past. I would appreciate it if someone could help me out with this problem.
181
I‘ve the same problem with the Werther.
182
Two times CTD with last version of JD330 and X-plane 11.50 when I try to see weather data for airport. When I press update or change to arrival airport X-plane crash.
183
Hi all! I've got a problem when shutting down engines. Engines goes to IDLE and that's it. Then i'm not being able to start my flight cold and dark. And i see that CRZ ALT goes down to the earth when i fly dct a waypoint after T/D
184
I have the same problem with the CRZ ALT when i fly dct a waypoint after T/D. also, when i load the plane, speed brake is in full position and it loads with FMC and FPS MESSAGE when i put the option in off in order not to appear that.
185
gsnipe wrote:
http://jardesign.org/forum/img/m/10560/t/p1eheuunlo1hh21c2i10bdog999j3.png
I also noticed that the CPDLC screen is not working on JD330-V4.0 RC3 as it should. It freezes whenever I press "update" after loading a FPL. (SAEZ-KJFK), find the FPL attached.
Repro Rate: 100%
Addons: ASXP, UWXP
XPlane version: 11.50 RC3
(On a side note: Enabling the GPU by pressing the green text that appears on the left bottom side of the screen, also causes a small freeze (2-3 secs)
If you have the xPilot plugin installed, remove it temporarily. And try again
186
I am exploring if anyone else is getting my CTD issue.
I have recently changed over to JD330-V4.0R2.
All system checks on setup are fine, including the responses from the FMC, when computing the data into the FMC.
My issue:
- I am however finding a CTD error when I am commencing T/O resulting from the FMC not computing the flaps setting i.e. 2/DN0.4.
- The Master Warn and Master Caution 'lights and bells' sound and then come on.
- Then when I cancel them both and clear the error in Status menu by pressing the 'clr' button I get an immediate CTD.
It's happened twice now, so I am assuming it's a bug somewhere in the 'coding'.
Has anyone else had this issue?
187
Repro Rate: 100%
Addons: ASXP, UWXP
WindSocks, I tried what you suggested. That's the issue! Disabling XPilot fixes the issue. Good thing is that we know what causes the issue now smile
188
There is no more annoying issue than the one that causes a CTD after 8hs flying tongue
- Entering a SPD Constr such as ".78" in the Vertical Revision page, causes a CTD in 4.0R2
189
You should fly 7 hours and everything will be OK lol  Question: What are you doing in all this hours? Don't you know that you can "scroll" forward to TOD to save time?!
190
Ilankart, please don't be rude. Some of us just fly the whole flight plan, because x-plane is a simulation and not just a game.
Otherwise, whether you are really still using version 11.30r3 as you stated in your signature ?
In this case do not comment on the latest problem with 11.50.
191 (edited by bascon1 2020-09-28 12:14:47)
a) What the heck is this mishmash of versions? Could somebody explain the logic behind? What is the current one?
v.4.0.4:
v.4.0.5:
v.4.0RC1:
v.4.0RC2:
R1:
R2:
b) "HOW TO INSTALL: Please not mix files with other version." Does that allways mean a NEW installation after a NEW version?
192 (edited by Homer.Simpson 2020-09-28 21:03:44)
a) R2 is the current one. (RC= Release candidate, R=Release)
b) yes
193
b) yes
Thank you a lot master, short and snappy! I luv those answers, greetz.
194
gsnipe wrote:
Repro Rate: 100%
Addons: ASXP, UWXP
Thank you for this solution.
Bought the JD A330 few days ago and a friend of mine told me how to geht the plane out of cold & dark. But then the "Update Button" failure crashed my game.
So no Vatsim flights with the JD A330 and xPilot.
And I also got another failure. During flight the Displays turn off, both engines turn off and restart immediately. But the displays still turned off. But when I click on them for pop out they work in the pop-out window.
Anybody have got this engine failure during flight?
Marcel
195
i bought this plane for almost a year but since i bought it no updates have ever arrived to improve it, there is a lot to work on this plane, a lot of things are missing that are on the real 330, i don't ask to have a 330 identical to reality, but at least one plane that is made in a decent way, I see updates of the 320, then I heard that the jardesign is doing the 340 and I'm glad, but at least finish the planes before making others.
Don't take it as a criticism, but as advice, because I spent some money on this plane and I wish they were well spent at least.
Best reguards,
Philip.
196 (edited by januzzu 2020-10-11 16:33:47)
Hello everyone,
i got a weird issue with the latest 4.0R2 version - after Start Engines!
See pictures here!
https://ibb.co/2YqJfkq
If i thrust up a little bit my Throttle, the Screens compare again. But if i stay in Idle, the Screens going to Black! I did the procedure like the real one or like lot of Youtube videos, but did not get this trouble with the Older version!
Please let me know what is going wrong!
My Sim: 11.50R3
Aircraft: JD330-V4.0R2
Drivers and so on are up to date
197
Anyone find a solution to the weather issue?
198
Hello JarDesign Team,
it´s nice that you´re still working on updates for the A330 but it would help the community much more if you could try to solve more issues within one update. In this forum are a few more people which have a problem with the weather when they use the A330. The A320 doesn´t have this porblem too and I have a lot more other addon planes which don´t have this problem too. Please try to figure out where this problem is comming from. Even if you reload the real weather and it looks than ok the plane will "reset" all the weather information as soon as you´re airborn. It has to be a problem with the plane itself and I can remember that I had this problem with an older version too but after an update it was solved. Please let me/us know if you have any further question to this problem. Just as an information. I already had a Skype meeting with screensharing together with Mr. Romanov a few weeks ago but without a positve result.
199 (edited by dandix265 2020-10-19 12:26:41)
Same for me. No wind update only with this aircraft. Still rudder flutterin a lot and still no weather radar displayed
http://prntscr.com/v2b3ck
and current live wind is 73kts/330
200
I have the following problems :
Speedbrakes are not working during landing phase even they are armed
Impossible to shutdown engines
Thanks for you help
