Re: XP11.50 JD330 v.4.1
I hope BSS fix their sounds
JARDesign Group Board → Downloads, Updates. → XP11.50 JD330 v.4.1
Unable to create XP11 aircraft icon files with this version.
You end up with miniature PNG icon images of (I think) the MCDU.
Someone reported similar issues with the latest JD A320 XP11.50 Beta.
Happens to me too and when I load the aircraft up, I just get a black screen with the FPS is too low message at the bottom. I hear sounds, but I can't see anything, it's a fully black screen.
Has anyone managed to get the BSS engine sound add-ons working?
Are new cockpit textures planned for the A330?
Greetings form Vienna
My PC: Intel i7 7700k, 32 GB, GTX 1080
So, I will make my Typerating for the A330 V4 and choose the routing LOWGLEPA.
Groundhandling is a little tricky.
TO, cruising and descent is OK.
But landing is infernal!
The A330V4 bounce against the runway 3 or 4 times. Regardless the A330 or A330-FPSBoost.
BSS-Sound not works in XP11.50 beta9 Version!
How do I activate this version? There is no activation window.
I was flying today from RKSI to RCTP and during short finals, I had a RAT OUT warning message on the ECAM. Both the Navigation displays went off for few seconds and then were back on. ELEC GEN 1& 2 and ANTI ICE 1 & 2 had FAULT light illuminated.
I don't have failures on, so not sure why did this happen.
Any inputs on this would be appreciated.
I am using X Plane 11.50b4 and JAR v4 for Vulkan as well.
1) I had the same issue twice on a flight from EINN to EGLL both times on short final yesterday. The first time made me miss my approach as I was fighting to regain my electrical power.
I had RAT out warning, Emergency GEN Fault light, Navigation displays went down but AtH stayed up as it accepted the TOGA command. AP went down because I pulled up. I had to turn on APU to get most of my power back on.
After a time when stable in my go around procedure everything came back to normal.
Then again in short final same issue. but by clicking on the Nav display I could read the info on the popup. This time I did not touch the stick in reflex and the AP still landed the plane as planned.
I have a no failure on setting and even when resetting them the problem wasn't solved
2 ) Also I noticed that when the Outer wing tanks transfer into the inner wing tanks, the rudder start to flutter until the outer wing tanks reach about 600kgs each. The flutter seems to be timed with the ticking of the fuel gauge.
I use X-plane 11.41 with JARA330 3.3r2
Hello I got JAR 330 V3.2 and activated without any problem. Now I download JAR 330 V4 and I can not activate, My serial code from the previous version doesn´t work, even doesn´t match, please I apreciate any help thanks.
you should open a ticket on support forum
http://www.jardesign.org/ticket/kb/index.php
In their FB group they said on the 21st that the update would be ready the day after on x-plane.org, but still no update.......!
Can be that they have run into issues. After having used the BSS sounds for quite some time and now have to listen to the default sounds is just ahhhhhhhhh.
Jan
Have an issue with latest beta..Error 1114 with plugins...any tip? (never had it with previous versions)
Does this solve the rudder flapping whilst in turbulence?
Hello JD330 users.
I'll find General Electric CF6-80E1 Engine Mod for JAR330 1.0.0 and try. It is very nice free modification and very good look engines.
Works fine with 11.50b9 and last update JD330 for this version. Instalation of this MOD is a little complicated, but with included manual no problem. You can look for this MOD and first look on this site:
https://forum.thresholdx.net/files/file … or-jar330/
Darko
Why isn’t possible to taxi on idle an thrust is always needed to be applied in order to taxi?
Depends on slope …
mco47a wrote:Why isn’t possible to taxi on idle an thrust is always needed to be applied in order to taxi?
Depends on slope …
I mean when its flat
jcdp wrote:mco47a wrote:Why isn’t possible to taxi on idle an thrust is always needed to be applied in order to taxi?
Depends on slope …
When it is flat you need thrust first because of inertia (you need to start moving aircraft) after you can reduce it but not necessarily down to idle .
BBS sounds downloaded today 3.0 works fine.
mco47a wrote:jcdp wrote:Hi
Depends on slope …
jcdpjcdp
usually the a330 can easily taxi on idle...even if its heavy...thats why i asked.
And thanks for your help
I've purchase the jardesign's license and it said i can use up to 5 backup activation.
For install the new version of the aircraft, does it spend 1 backup activation?, or i can update the new version unlimited time on the same pc?
When you reach out of activation you just send a message with your purchase reference to JAR for getting a few more without any problem .
HOW TO GET REGCODE?
HOW TO GET REGCODE?
Buy the aircraft and you get it
PS: you should avoid capital letters ….
I have downloaded the latest version and installed into "aircraft" folder but it does not show up in the list of aircraft to select.?? I have done this a number of times but never seen this.
