Re: XP11.50 JD330 v.4.1
I purchased the A330 in xplane 10 and have downloaded the install for xplane 11? Will it still work? I have tried and it activates successfully but some of the switches dont work/
Hello, I purchased my 330 through this website and now when I install this version it asks me the serial key and I can't find it anywhere.
I opened a ticket issue but no response...
Thanks for any help,
Miguel
Miguel
If you really buy you get a confirmation with download and series number ! Look at your confirmation mail..
No! You have to buy the XP11 version
80 (edited by dwibishop1123 2020-04-22 14:41:24)
delete...
Recently the engines of the aircraft fail during takeoff, automatically turning itself off and on again.
what should i do about it
thanks.
Mate, A330 with Vulkan b4 - is constantly crashing - just on ground - trying to set it all up.
Please can we fix it asap?
thanks
FMGS: 543 : PluginPath=C:\X-Plane 115\Aircraft\Airbus330\plugins\fmgs\
FMGS: 543 : AircraftPath=C:\X-Plane 115\Aircraft\Airbus330\
FMGS: 544 : PluginPath=C:\X-Plane 115\Aircraft\Airbus330\plugins\fmgs\
FMGS: 544 : AircraftPath=C:\X-Plane 115\Aircraft\Airbus330\
FMGS: 545 : ICAO-format plan export to Dataref: WSSS SID VMR M771 RAXIM M771 OTLON M771 VISAT M771 DUBSA M771 DAMOG M771 DOLOX M771 DUDIS M771 DAGAG M771 SUDUN M771 DAMVO M771 DOXAR M771 NITOM M771 DAMEL M771 34BC M771 DONDA M771 DOSUT M771 DULOP Q1 CARSO V551 SUKER V542 HOCKY V551 CYBER V542 BETTY STAR VHHH
FMGS: 665 : Add points: 1
FMGS: 674 : add Leg: VMR5E,CF,TOPOM,1.498611,104.040833,0,VTK,12.3,5.1,23.0,10.0,2,2000,0,0,0,0,0,0
FMGS: 674 : add Leg: VMR5E,TF,ATRUM,1.548889,104.015833,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,0
FMGS: 674 : add Leg: VMR5E,TF,AKOMA,1.756111,103.911944,0, ,0.0,0.0,0.0,0.0,2,7000,0,0,0,0,0,0
FMGS: 674 : add Leg: VMR5E,TF,VMR,2.388333,103.871667,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,0
FMGS: 674 : Add points: 5
FMGS: 676 : ICAO-format plan export to Dataref: WSSS SID VMR M771 RAXIM M771 OTLON M771 VISAT M771 DUBSA M771 DAMOG M771 DOLOX M771 DUDIS M771 DAGAG M771 SUDUN M771 DAMVO M771 DOXAR M771 NITOM M771 DAMEL M771 34BC M771 DONDA M771 DOSUT M771 DULOP Q1 CARSO V551 SUKER V542 HOCKY V551 CYBER V542 BETTY STAR VHHH
FMGS: 687 : ICAO-format plan export to Dataref: WSSS SID VMR M771 RAXIM M771 OTLON M771 VISAT M771 DUBSA M771 DAMOG M771 DOLOX M771 DUDIS M771 DAGAG M771 SUDUN M771 DAMVO M771 DOXAR M771 NITOM M771 DAMEL M771 34BC M771 DONDA M771 DOSUT M771 DULOP Q1 CARSO V551 SUKER V542 HOCKY V551 CYBER V542 BETTY STAR VHHH
83
The new version A330 works excelent in XP11.50 + Vulcan. BBS sound we`re can fixed. Copy win.xpl (from default JD330. plugins/sound3d) and OpenAL32.dll (f.e. default JDA320, plugins/sound3d) to JDA330 /plugins/BBS folder.
X-Plane 11.30, JarDesign A320, Jardesign A330, Jardesign X-Life Deluxe, Jardesign Ground Handling Deluxe.
Why is it crashing then?
I am using the fmod sounds for 330
Unable to create XP11 aircraft icon files with this version.
You end up with miniature PNG icon images of (I think) the MCDU.
Someone reported similar issues with the latest JD A320 XP11.50 Beta.
great work!
Yesterday evening I programmed my second flight from EDDM to EDDH, but there wasn't a sign of T/D etc. at the ND or FMGC during flight in CRZ. During my first flight from LFBO to LSZH (I studied your Video tutorial before) I didn't notice a sign of T/D, too.
What did I forget or what didn't I not set?
Have a nice day and thank you!
Rolf
87 (edited by hknpal 2020-04-27 14:30:16)
its working good with 11.41 just some two things I saw. fps_boost vers a330's cocpit ND bright switcher is looking weird. and this big bird somethimes exits the route after then wawing and find the route again. plus I dont know its problem or but I wanna say; when taking off on rolling runway even say no "V1" nose go up interestingly.
Thanks for updates
works good for me. BSS is now working well. I have just put only win.xpl from sound3d to BSS. and it looks great without any troubles with crashing
the flat controller does not work
Hi, this Aircraft looks fantastic in VR but its not flyable in VR because there are a few things that do not work.
Flaps
Gear
ALT push pull and adjust
HDG push pull and Adjust
Speed Push pull and adjust
I think these things are letting the Aircraft down. A lot of us fly in VR now and most other payware Aircraft work fine in VR.
Please could this Aircraft be updated to work properly in VR?
Its a shame as it is a good Aircraft and im sure it would be appreciated bye a lot of people.
thanks
carl
I saw RAT OUT message today and when I am taking off,  ND panel goes BLACK
Hi Support
I have exactly the same issues as quoted below
Running 11.50 Beta6 and Latest A330 can anyone assist on this or do I need to submit a support ticket
If you require any furhter information please just let me know
Thanks in advance
Paul E Lee
hanish_taurean08 wrote:
Hello.  I tried the latest version today and had issues with it, not sure what went wrong. The aircraft does not follow AutoPilot after takeoff, it stays in takeoff pitch and hdg or just follows any random direction, speed keeps on reducing and then aircraft starts swinging sideways and stalls to crash. I tried clean install 3 times and exactly the same thing happened all the time.
93 (edited by luyijie12 2020-05-01 16:15:50)
paulelee46 wrote:
Hi Support
Thanks in advance
Paul E Lee
Excuse me, do you use BetterMouseYoke?Please remove it if you use it.I had this problem before.
Hi hanish
No never heard of this add on
Thank You
Paul
95 (edited by noisimus 2020-05-02 13:27:23)
Edit: I am big dumb and enter wrong text, please delete
96
Tire dimension being fixed in this version? See my previous post XP11.41 JD330 page 6. In short: tires should be wider
I'm getting a problem where the MCDU keeps coming up on the bottom left of my screen. This is causing my game to freeze. It doesn't crash the game as I can still hear the sounds change as I enter different views on my Numpad. However, the screen is completely frozen. I can access all the other stuff on XPLANE such as the plugins, flight configuration and etc. It's just the main screen which is frozen.
In the image attached, you can see the thing that pops up in the bottom left of the screen. As soon as it pops up, my main screen freezes. But the plane still climbs in altitude, follows navigation, makes different sounds when I change views, however, I can't see the views being changed as my screen is frozen and I can also Pause the game, access the plugins and etc.
https://i.imgur.com/aX7Axda.png
Doesn't affect gameplay, but when trying to stream using OBS Studio, the game capture only picks up the FMS Screen not the regular views. This happened during v1 thru v4.
Hello there smile
I've always had great fun flying the Jar A330 however as of yesterday, I've only been having problems to the point where it's impossible to do a flight, it started by doing a flight from Athens to Zürich, during the last phase of climb approx 3000ft before final cruise of FL400 both engines switched off and immediately restarted and that kept happening. I decided to try a different flight, this time it did again but from the starting position on the ground, I couldn't even taxi. On the 3rd try, the engines didn't start up properly and it's like the cut off and ran at the same time, the fuel flow was flickering between 0 and 265+- KG/H.
Also to note, I'm on the latest version 4.0.5, I have the same issue with every other version. All my other planes are in a working condition and have no issues like the A330.
Hopefully someone can help as I really miss flying the A330, my favorite long haul plane smile
I agree with midi48 on the issue of VR flights. Good model, but poorly made for VR. I hope Mr. Romanov will spend some precious time and fix everything in the upcoming release!
Flaps, Gear, ALT push pull and adjust, HDG push pull and Adjust, Speed Push pull and adjust, Baro ref push for set standard and ajust.
Thank you in advance.
