226
Re: XP11.50 JD330 v.4.1
philwhite100 wrote:
I have just downloaded and installed it into XP11.51 then when i entered the activation code from my original X-Plane org store purchase it says it is invalid when i copy and paste it in.
I did make sure i entered the correct code.
Any ideas what could be wrong.
I SUSPECT THAT YOUR HAVING ISSUES BECAUSE HE HAS NOT UPDATED SHIT TO RUN WITH 11.51. IM RUNNING 11.51 AND HAVE NOTHING BUT ISSUES.
227 (edited by mikie46 2021-01-10 04:18:25)
ACA235 wrote:
betty2k wrote:
Hi J.A.Romanov
The Engines in V4.1 RC2 cannot be switched off by the engine-master. Are you serious?
Also: I am doing an approach. Before the approach begins I have reduced the IAS to 220 knots in the MCDU. After "Approach phase is activated" the limit for the waypoint is over, and my aircraft speeds up like in TO/GA-mode.
I think, the A330 V4.05 is even better developed. Why are you doing that? Why is the plane getting worse and worse from update to update? Are you updating an old file with bugs?
***I have the exact same problem and a lot of other ones as well.  Not sure if this aircraft was tested properly before release but I am furious that I have wasted $70.00 on this.  I dont even know where to list all of the bugs that I have found on this aircraft or if anyone will even care.  Just to point out that I fly for a major airline in Canada
DO A CHARGBACK. THATS WHAT IM DOING. IM DONE WITH THIS ASSHOLE AUTHOR! HE DOESNT SUPPORT THE PRODUCT AND THERE IS NO SUPPORT. I PURCHASED 2 PLANES A320 AND A330. NONE OF THE PLANES WORK AND THE COPILOT HAS NOTHING BUT BUGS IN IT. SO IM GOING TO CHARGEBACK $100. TO HELL WITH JARDESIGN!
228
@mikie46, I think, I'm hoping, the best way to have support is here or  skype
Here...we are alone ☹
229
What do I have to do to get my money back?
230 (edited by dandix265 2021-01-11 23:17:03)
i don't think you will have money back.. This airplane sucks. And we recognize it later sad
231 (edited by puretone44 2021-01-14 14:02:00)
Hello. Love your A330, but whenever I click on the metar update button on the panel, my game crashes. I have the newest version and XP 11.51.
I cannot provide a crash log since I have to force the game to exit.
232
Just read before post and update with last version
233
I had this issue before but I discovered I had a pluggin "HangarOps" installed . Removing this pluggin made the aircraft wprking very well without crash when using metar update button .
234 (edited by dandix265 2021-02-09 17:35:04)
Hello. With last update R4, turbolence yaw damper added in changelog but i can't still fly without hard turbolence. Still unflyable
Any news of this?
235
Done and got my money back and filed a complaint with the .ORG store.
This guy is a crook
mikie46 wrote:
ACA235 wrote:
betty2k wrote:
Hi J.A.Romanov
236
gsnipe wrote:
There is no more annoying issue than the one that causes a CTD after 8hs flying tongue
- Entering a SPD Constr such as ".78" in the Vertical Revision page, causes a CTD in 4.0R2
You should fly 7 hours and everything will be OK lol  Question: What are you doing in all this hours? Don't you know that you can "scroll" forward to TOD to save time?!
How can I "scroll" to TOD?
237 (edited by Fab10 2021-03-07 18:09:59)
Still having issues with ghosted nav lines on the ND which do not appear when ithe ND is in windowed mode.
https://www.dropbox.com/s/u32ikt5wxpsmb … 0.JPG?dl=0
238
Not compatible with XShade.
239
Report on screen problems,
When working with xEnviro, a black square will appear in the lower right corner of the screen,
This has never happened on other plug-in aircraft.
