176
Re: JD320 Airliner ver 3.4 r3 WIN/MAC 64 bit (X-Plane 11.35-11.41)
luyijie12 wrote:
Activation being 'please wait'.What happened?What's the solution? l just bought it.
Maybe your firewall block online connection.
177
Nice!Thank you so much.
178 (edited by toranamadman 2020-02-16 03:01:09)
Makcimus wrote:
Мной было найдено решение для устранения ошибки получения METAR данных на панели DCDU вызванное конфликтом с плагином GIZMO.
Для этого необходимо выполнить следующие действия:
1. Скачать обновлённую библиотеку
2. Скопировать новый файл библиотеки в директорию с заменой:
"папка X-Plane 11\Resources\plugins\Gizmo64.plugin\64\ "
!!!Перед копированием не забывайте сохранить оригинальный файл!!!
Приятных полётов!
I found a solution to eliminate the error in receiving METAR data on the DCDU panel caused by a conflict with the GIZMO plugin.
To do this, follow these steps:
1. Download attached libcurl.zip file, unZIP it, you will get libcurl.dll (the updated library file)
2. Copy libcurl.dll file to the directory with the replacement:
"X-Plane 11 folder\Resources\plugins\Gizmo64.plugin\64\"
!!!Before copying, do not forget to save the original file!!!
Have a nice flight!
https://sun9-55.userapi.com/c200820/v200820667/469e3/s4oAip0Asks.jpg
I have tried all these steps including the gizmo update with no success
179
What is your operating system? I have Windows 7. I can send you my gizmo plugin for testing. I need Your email to send
System: Core i9 11900F ~ 5,2Ghz , 32Gb DDR4 3200MHz, NVidia RTX3070Ti 8Gb, W10Pro. 64 bits, SSD 512Gb, HDD 4Tb
Monitor: Samsung SyncMaster S27A650D (1920x1080)
joystick: TrustMaster T.Flight Xotas X
Sim.: X-plane 11.55r1
180
I'm using Windows 10 . My email is torana_mad_man@hotmail.com
181
Sent, try to install
182
Your script "Systems created" overwrites the saved Situation.sit files.
How can I avoid this?
183
Is it possible to turn of the window reflection at the cockpit window? Especially at night is the thrust lever reflection to bright. Its almost impossible to look through the front window.
184
This option is already implemented in upcoming version
185
@dron420 is there any plan for new version ? and if yes when ?
i think competition becomes hard for jardesign , FF320 Toliss 321. i hope u be succesful and hurry
186 (edited by Arbus77 2020-03-06 22:51:52)
Hello, I have this black dot on every livery. Any way to fix it?
187 (edited by sidiclei 2020-03-07 15:46:27)
Hello there! this morning when I was flying my A320, on final approach the auto pilot disconnected out of nowhere and the aircraft push its nose up and start climbing again. I tryed to take control of the aircraft but it did not responded to any of my commands using my joystick and when it responded it dropped the aircraft on the ground not letting me have a chance to recover the landing in any way. Does anyone now what's going on? I have the latest version 3.4 r1 installed. The entire flight was perfect but the landing. Thank you for your help.
188
it is change in 3D model. Need just to paint this hole on livery.
189
http://jardesign.org/forum/img/m/9812/t/p1e2su91givoa602vkd1vd8623.png
@dron420 Thx for your answer. How about the logo lights? They seem to be out of position.
190
All lights are rebuilded in upcoming version
191
When approximately you will release new version?
192
are there any plans to see these items in future updates?
Self test in progress (max 40s) on startup
RCDR active (on checklist)
Button PA active on radio 3
Lights active on Windows
Open both windows
button VHF1 2 INIT and CAB on radio
BRT MCDU
And ChecklistACTIVE AFTER FIRE Engine on screen
193
We are working on.
https://b.radikal.ru/b16/2003/76/0370b24d29cf.png
194
Its the second time i tried to fly and i had same crash problem at final approach
log https://drive.google.com/file/d/1Bs3bJP … sp=sharing
195
Приятных полётов!
Have a nice flight!
Thanks a lot! This does help me out!!
196
You're welcome!
197 (edited by Makcimus 2020-04-04 07:13:07)
Программа SkyMAXX обновилась до версии 4.9.0 с переустановкой плагина GIZMO. Нужно повторно переустановить библиотеку "libcurl.dll" так как был возвращён старый файл.
Program SkyMAXX has been updated to version 4.9.0 with reinstalling the GIZMO plugin. Need again to reinstall the library "libcurl.dll" because the old file was returned.
198
When will there be an update for 11.50 because everytime I try to play on 11.50 it crashes? On 11.41 it's fine.
199
v11.50 is still a beta version …  , not a stable version    so …
X-plane 11.50 is in beta, so compatibility is not guaranteed. When the version is released, then there will be an airplane update.
