Re: JD320 Airliner ver 3.4 r3 WIN/MAC 64 bit (X-Plane 11.35-11.41)
mikeapo wrote:
Hello!!! What is going on here? https://i.imgur.com/vsdkYBf.jpg  I write about the night textures of MCDU!!!
You should remove all cockpit textures from your custom livery folder.
Hi! My landing and taxi lights are not visible, how fix it? I was reinstall and activate the plane. On the default planes lights is ok.
Добрый день! Фары и рулёжные огни не горят, хотя световой пучок под самолётом есть. Как это исправить? Самолёт переустанавливал. На дефолтных моделях свет нормальный.
What does exactly wrong with? Spot light on lamp itself? Could you show any screenshoots?
79 (edited by dnfdw 2019-09-21 14:33:30)
http://jardesign.org/forum/img/m/9142/t/p1dla3f5o01qp5b2jrvhm1c1f4s3.jpgLights on.
http://jardesign.org/forum/img/m/9142/t/p1dla3ktv6ije1r33d7iiq71f8b.jpgZibo 737 for exemple.
Hello, i updated the aircraft as per instructions and when i load in it doesn't have any gear with the gear lever down and has a beeping sound through the headset any solutions?
No ILS detected after updating to Xplane 11.36
Any idea on how to solve this??
Could you show me the S7 custom livery folder content?
How to do it? In the default livery lights don't work too.
In the night it is work!
http://jardesign.org/forum/img/m/9142/t/p1dlce4rcmqktvkb8921lc7que3.jpg
i have this problem too , have problem with taxi lights at day only !
i have another problerm , with latest airac , when i want direct to a point that not in my fplan , i got error missed data ! whats solution ?
86 (edited by King5torm 2019-09-23 06:59:32)
Any ideas to fix, fresh install too
87 (edited by dron420 2019-09-24 07:09:38)
What version do youi have?
https://a.radikal.ru/a32/1909/66/b0555080d6ec.png
88 (edited by vahooli 2019-09-24 10:03:05)
jar 3.4 r2
xplane 11.36
airac 1910
i was in a route between LSGG - LOWW, atc says direct to NERDU, ihavnt nerdu in my plan so i should write that in drct page, but had error missed data!
I have jar 3.4 r2 and xplane 11.36 version too.
90 (edited by F1le 2019-09-24 23:51:28)
That's JAR biggest problem... MCDU needs to be fixed. It works fine until you program it and do not touch it. Once you have to mess with it, due to ATC instructions ... like :
- follow point you don't have
- Changing STAR and RWY
- Force different fly-levels on points due to ATC requests
You are DONE. Mostly you will have to land by "hand" as ILS will be broken too, when those bugs will occur.
I am begging JAR to fix this MCDU mess, as that's the only one thing (key thing) that force me to rarely fly with his planes.
The lights is work in ver. 3.3r3.
http://jardesign.org/forum/img/m/9142/t/p1dlnfohd71ub1ofie31so41ldg3.jpg
and again on live event, i have DM455 in fms near the munchen , atc said direct to DM458 , and in dct page had error missed data !
2problem i hope solve in next version ,
lights at night , and FMS
93 (edited by claudioplanno 2019-10-02 18:16:49)
After installing my A320 Jardesign I get the message that it was successfully activated, but my aircraft panel is left without MCDU and no ARC / NAV model on the panel. Am I doing something wrong? Because I was already flying with this aircraft and I was upgrading and gave it.
Anyone Help me?
Good day
after installing the updates JD320XP11_345 b, the new version cannot be started.
I've talked about it before, due to the many Xplane updates, always the JD has to. program needs to be re-downlaod.
I ask them to unlock.
With best regards
Dieter Hybbeneth
rdhybbeneth@web.de
95
And much worse, the more you install the new version, the less it works, will really have to make a big effort on the future version ...
I give up the JD320 too galley ...
cordially
96 (edited by lokvik 2019-10-05 09:56:27)
здравствуйте
мой серийный номер не подходит - самолет не активируется
не летал в симе лет 5 - сейчас вернулся не могу активировать
покупал на x-lane.org - там в кабинете версия какая то старая - обновлений нет и суппорт с неработающим номером помочь не может.
моя почта lokvik собака gmail точка com серийный номер 8F-WC****-4****Y-C****2-T****M
lokvik wrote:
здравствуйте
Открываем тикет со своим старым серийником и запросом на новый
http://www.jardesign.org/ticket/kb/index.php
Все обновления на этом форуме.
cordially
JD A320 work's well and correct. With last version I'll fly over Europe without any problem and all sistem's work's fine.
My configuration you can see in the bottom.
Here is picture from tracking flight in LittleNavmap of this flight's, about 30 flights (complet depart and arrivall's)
http://jardesign.org/forum/img/m/4390/t/p1dmlgvnhm815i4p16q21u9017bn3.jpg
Is this latest version 3.4 plugin compatible with Mac OS Catalina released yesterday, before I upgrade?
100 (edited by domined39aniello 2019-10-09 00:04:15)
Hi Sir problem with Catalina.
