Topic: v1.2b1
Today we get a new version from SASL developers and I just make pack with it.
If you:
- use MAC, please try this version and report CTD if will be!
- want to listen ZEK custom sound pack, please try this version and report what you think about sound!
Please install it as clear installation, not use custom sound pack, not mix files with other version, but sure, install NavData update if need.
If you have a CTD at MAC, please place reports direct here (log.txt file and MAC crash report). This version build to understand how new mac os SASL base plugin stable on MAC.
Download link http://jardesign.org/a330/download/inst … v1.2b1.zip
If you have crash at first start, please try to delete custom sounds (delete all files) from ..X-PLANE 10/Aircraft/330_JARDesign/plugins/sound3d/custom/
Re: v1.2b1
it doesn not start - direct CTD. Mac 10.10.4, X-Plane 10.40b5.
Maybe related to sound.
Time Awake Since Boot: 12000 seconds
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000068
VM Regions Near 0x68:
    __TEXT                 0000000000010000-0000000000037000 [  156K] r-x/rwx SM=COW  /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   libsystem_c.dylib                 0x00007fff98f52e07 flockfile + 4
1   libsystem_c.dylib                 0x00007fff98f54b7f fread + 31
2   mac.xpl                           0x00000000854f2f8c sounds3d_class::LoadSound(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >) + 134
3   mac.xpl                           0x00000000854efbbb sounds3d_class::loadfile(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >) + 57
4   mac.xpl                           0x00000000854ed95d ReadCFG(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >) + 2584
5   mac.xpl                           0x00000000854ecb2b ReadINI() + 1854
6   mac.xpl                           0x00000000854ef242 Main(int, int, void*) + 47
7   XPLM                              0x00000000116b4291 XPLMDispatchDrawingHook(int, int, int) + 121
8   XPLM                              0x00000000116b4386 XPLMDisplayDoDrawingHook(int, int) + 174
9   com.laminar_research.X-Plane      0x0000000100b5cef2 XPPDoDrawingHook(int) + 114
10  com.laminar_research.X-Plane      0x0000000100b7412c WORLD_scene_per_render(rendering_pass, float, float, float, float) + 1100
11  com.laminar_research.X-Plane      0x0000000100b79654 WORLD_scene_per_frame(int) + 2100
12  com.laminar_research.X-Plane      0x00000001005968b7 APP_update() + 3063
13  com.laminar_research.X-Plane      0x0000000100e6a2be MACIBM_post_event_proc() + 222
14  com.laminar_research.X-Plane      0x0000000100e475eb WIN_run_app + 43
15  com.laminar_research.X-Plane      0x00000001005986a7 main + 103
16  com.laminar_research.X-Plane      0x00000001004904d0 start + 52
I tried and replace sounds and sound plugin with 1.1b5.2 - started. Testing now.
Thanks,
Tim
3 (edited by meistersoda 2015-07-13 18:40:55)
Re: v1.2b1
first CTD around 1:30 min after loading.
Have to say, Gizmo and SkyMaxx 2.1.1 enabled - see my last post in the old beta.
Attaching logs.
Cheers,
Tim
Re: v1.2b1
CTD Win 7
Sound3d: Custom soundpack will use F:\X-Plane 10 -4b3\Aircraft\A-My Fly\330-1.2b1\plugins\sound3d\custom/set.ini
error: mv_DRF == NULLsim/custom/xap/snd/eng_vol_01
error: mv_DRF == NULLsim/custom/xap/snd/coc_vol_01
!!!Cannot open WAV file.
bbox
>>> zulu 11:32:55
    baro alt=0 / rad alt=0
    air spd=0 / gnd spd=0 / mach=0
lat  wait = NAV
active wpt = 0
Mike
hmm
Re: v1.2b1
Hi Mike,
try to replace "sounds" folder and sound plugins with the ones from an older beta.
Cheers,
Tim
MikeMJD wrote:
CTD Win 7
Logs.
log.txt for X-Plane 10.40b5 (64-bit build 104009) compiled on Jun 30 2015 16:13:41
X-Plane started on Mon Jul 13 19:43:15 2015
bbox
>>> zulu 11:32:55
lat  wait = NAV
active wpt = 0
Re: v1.2b1
That worked many thanks.
Mike
hmm
7 (edited by Luke173 2015-07-13 22:19:50)
Re: v1.2b1
crash during loading of acf..
logs attached
Attachment icon bbox_log.txt 119 b, 262 downloads since 2015-07-13
8 (edited by Luke173 2015-07-13 22:31:49)
Re: v1.2b1
clean xp installation, same result:
Attachment icon bbox_log.txt 119 b, 253 downloads since 2015-07-13
Re: v1.2b1
Hi Luke,
please try to replace "sounds" folder and sound plugins from an older beta. I mentioned this in the post before.
Cheers,
Tim
Re: v1.2b1
Ok, thanks for trying - it have the same CTDs, like old versions.
As I understand, custom soundpack not work correct too.
So, close it now.
