Topic: Same procedure
for my Peter Hager Airbus-Fleet I tried to create the sets. But it is not possible. The plugin creates for every plane (A319, A320, A321) only a AirbusIndustrie.set. So it is unpossible to get different set for the three planes at the same time.
The only way is to take the set of the A320neo, copy and rename it for use. Then you have to copy the AirbusIndustrie.set, save the first and separate it. Then change the values in the new file and repeat this procedure for the third one.
But every time you like to use a special set you have to move the suitable file into the custom folder and remove the one you actually not need. That worries so.
TugMaster produce problems with Peter Hagers planes too. After pushback the front gear and the rudder is out of work. We talked about that. BetterPushback brings no problems while working.
Sorry but now it seems that there is an attempt to eliminate competition.
with Regards
Olaf
