1 (edited by lmoramontiel 2019-05-12 02:01:17)
Topic: Warning: GHD plugin not instaled
Warning Ground Handling plugin not installed on the A330 although it does work. This comes out only with the A330 since I bought GHD Deluxe, it works perfectly on both the A330 and other aircraft, but only on the A330 comes the warning message as if it did not have the plugin installed. Don´t work from MCDU, only for the pluings.  What could it be?
Re: Warning: GHD plugin not instaled
This may happen if your JD330 version or GHD version is not fresh / actual. You can download actual versions from this board.
I have the A330 version 3.1r3 and GHD_070319
You were right reinstall the GHD and now it works perfectly, thank you
