Topic: CoPilot for FF767 Beta-tests
So, this is CoPilot plugin for great Flight Factor B767-300
We are on beta-stage now.
http://jardesign.org/forum/img/m/22/t/p1d8tf9gniqk315nq1ekkm7e4b3.jpg
features:
+ animated 3d CoPilot model (male, "Sandy")
+ can recognize and execute voice command
+ can speak
+ can read checklists
+ can operate with Events (flight parameters detection)
+ man and woman copilot model (man only included this time)
+ scripts based (possible to edit/change Procedures/Text/etc)
This is a payware product, but now it is testing stage, you cant buy it right now. But you can download and install the demo version. If you like the demo version and you want to test the full version - You do not need to hesitate. We have prepared 25 keys for our beta-testers. You can take part in testing and leave us your feedback. If your review useful for us, we will not deactivate your key in the future - please use it.
STEP-BY-STEP
0. Check you are on MAC or Windows (no Linux, sorry)
1. Install and activate aircraft version compatible with CoPilot (FF767-300 v.1.2.13), check it work
2. Download and unZip CoPilot plugin Demo http://jardesign.org/copilotdownload/JD-CPL-767.zip
3. Setup speech/recognition engine at your computer (read manual in ZIP pack)
4. Install CoPilot plugin Demo to your 767 aircraft "/plugins/" folder. (read .pdf manual for details)
5. Load aircraft, reload if need, and check what you see copilot in cockpit, it animated, speak and recognize your voice command.
5. Demo mode work up to takeoff phase of flight.
6. If you prefer use full version, use X-Plane Menu->Plugins->YourAircraft->CoPilot- >Registration to run activation procedure, BUT:
UnInstall (if need): Delete 767-300ER_xp11.acf file from this aircraft folder. Rename 767-300ER_xp11.acf.backup file to 767-300ER_xp11.acf - you will get original .acf file. Delete "/copilot_main" and "/copilot_speech".
On beta stage, to get serial key to unlock full version you may create a ticket at our www.support.jardesign.org with free form, but please be sure what you wright your forum NickName somewhere and you have at least some messages here. Another way - use my skype if you already have it. Please review/discuss beta-version here. Please be constructive, positive and respectful.
Re: CoPilot for FF767 Beta-tests
I´d like to test it. But I couldn´t open a ticket herehttp://www.support.jardesign.org/.
You may use skype j.a.romanov for direct contact, sure.
So... I tried to make a voice test and the plugin don`t respond my command. How topic on support forum I can report this? I don`t have skype!
Hello everyone, I opened a ticket and would like to participate.
Kind regards.
Yes, here. Sure, on this stage we can assist you using skype only.
Just registered to say this;
What a briljant idea! Would seriously buy this for every aircraft I own. Would love to beta test the plugin.
Ok... I`ll try to contact you.
9 (edited by chris.palfreyman 2019-04-27 08:44:36)
Hello JARDesign Team,
Two full gate to gate flights completed using Sandy in 767-300ER.
Issues (I) or my Observations (O) as below:
1) I - Upon start up Sandy says "Pack 1 and 2 Auto" - this is not required.
2) O - There is no "flight control check"procedure
3) I - I cannot get a response to "Checking Brakes" and the script stopped here. I could continue by saying "Abort"
4) I - When Sandy sets the Seat belt and no Smoking signs on he does them the wrong way round - he points to No Smoking but says "Seat Belt" and vice versa.
5) O - During the before take off checklist - Sandy refers to "Speed Brakes" - the speed brakes are not set for takeoff in the 767.
6) O - The Descent procedure is missing. The Lading Altitude, Recall, Autobrake, VREF and MINS should be set in this flow.
7) I - The Localizer Arm command does not work
8) O - Approach mode Arm command is missing.
9) O - Occasionally the scripts stop. They can be re-started by saying "Abort" but this isn't intuitive.
Otherwise this works great and is very immersive.
I'm continuing testing so will update this list if I find any other issues.
Kind regards, Chris
Hi Eugeny,
It would be nice when the copilot would handle the taxi lights (in a "taxi procedure").
Regards, Pieter
We just update plugin. Please use the same link for download Some changes / improvements was done based on our testers review. You may delete exist "custom" folder placed at ../plugins/copilot_main/custom/ and paste new "custom" from ZIP.
pieterdejong wrote:
Hi Eugeny,
Regards, Pieter
He can, but just after getting Capitan command only. But we think to add this "event" on taxi, to set ON lights if this was not happen before. Thanks!
ok, beta period is closed. Thanks ALL for your opinions and reports. Sure, all beta-testers may keep serial and use it with release.
