Hi JAR
I've done a couple of flights with the version of the b4 with copiolot. So far, it all works just fine.
I noticed, however, I have find a couple of problem with the use of MCDU. The use of HANDLING/TOWING allows you to:
- handling with chocks and GPU correct
- if I press first STAIR they call both of these stairs, the same is with press CATER
- loaders not exist in menu, they exist PAX/CARGO but this you can use direct from MCDU menu.
- the doors are no opened auto
- you can call stairs, catering and fuel only once.
Using Toolbars, the same is happened, and checklist don't work for me, maybe due to the use COPILOT so I don't need it.
Using GroundHandling everything works fine.
Thank's you for all updates and improvements with your's products.
My Fleet: JD320-V3.8R1 with copilot, JD330-V4.4B3 with copilot, ZIBO 737-800X,
