Re: JD320 v.3.4 public beta
With X Plane 11.33.b1 works ILS Frequence korrekt.
JARDesign Group Board → Beta-versions (Download & Discussions) → JD320 v.3.4 public beta
anyone who knows how to change the passenger amount that can be loaded on the A320?
i use 11.32r2 and my mcdu and fmgs is black dont work for me waiting for new version but 3.3 and working fine
Hi Sir A320 3.4b3 is out . Download in to page 1
joval wrote:i use 11.32r2 and my mcdu and fmgs is black dont work for me waiting for new version but 3.3 and working fine
for me 3.4 b3 not working mcdu and fmgs is black I've tried 3 times but not work
this comes up with every version of my jardesign 320 (active full version, and this beta), making it completelly unusable for some time already
the activation window does not come up, so it seems to be activated from previous versions.
what can i do? thank you.
already happened to me and I discovered that it was a plugin that I had in this case was zibocopilot takes out the plugins all and tries one by one
hug
you were right, joval, it seems i had sasl in plugins, and it was interfering... removed that, and it all works again.
thank you
X Plane 11.33.r1 crashes again and again.
ERROR Windows Modul KernelBase.dll
hi i use windows 10, xplane 11.32r2 and jardesign version 3.3 working very fine but 3.4beta 4 notwork for me mcdu and fmc is black
I know thanks.
I meant : JD A320 v.3.4 public beta and X Plane 11.33.r1 (comes with a new installer).
Hallo Augeny,
Really current .
Now XP 11.33.r2.and XP 11.34r1 with JD A320 v.3.4 public beta and NavDataPro 1905.
Crashes again by input the departure data in MCDU.
By NavDataPro 1904 worked OK
My JD320 v.3.4 public beta suffers CTD which is intermittent, but is almost certainly to do with the way the aircraft reacts with the weather system in XP11.30. The most common CTD occurs when I activate the weather radar switch when bringing the aircraft up from Cold and Dark. I am using Skymax Pro. The last lines of the log.txt in the latest CTD situation read :
"FMGS: 0 : MessageGreen: Systems Created!
SkyMaxx Pro: Activating METAR parsing.
SkyMaxx Pro: Found new METAR.rwx file
SkyMaxx Pro: Parsing METAR data
SkyMaxx Pro: METAR parsing took 2120 ms.
FlyWithLua Info: Searching for Lua quarantined script files
FlyWithLua Info: The folder /Resources/plugins/FlyWithLua/Scripts (Quarantine)/ does not exist or it is empty.
SkyMaxx Pro: METAR parsing took 200 ms."
UPDATE:
NOW SORTED
Hi, Hope someone can help me, I brought this aircraft yesterday, and Updated the nav cycle, as if you look on the NavData pro image, it shows I have entered the right path for the aircraft, and I checked after install and it has got to the custom data file in the aircraft folder. Is there something I maybe doing wrong? looking for your help!
Please the photos with the above link, as I'm not sure how to upload photos!
"Initialization error
could not initialize FMC for current aircraft due to the following error
Failed to find dataref:sim/custom/xap/mcdu/title_g"
That is the message when trying to use WebFMC pro.
Working fine with A330.
Any solution?
domined39aniello wrote:joval wrote:i use 11.32r2 and my mcdu and fmgs is black dont work for me waiting for new version but 3.3 and working fine
Same problem here. Maybe because I'm using LINUX?
joval wrote:domined39aniello wrote:Hi Sir A320 3.4b3 is out . Download in to page 1
one question you have many aeroports with ground traffic?
in custom scenery put litlle aeroprts with ground tfaffic 7,8 and test for me working fine now
regards
Hallo Augeny,
Really current .
The new cycle 1906 worked properly.
Cycle installed in 330 and not in 320 path (NavDataPro ).
Any plans to add wing flex to the A320??? Wing flex during flight (turbulence)/ ground taxi??? Access to wing flex adjusting through X plane 11 Plane Maker???
It kind of sux paying so much for this plane and you can't have access to adjust this and no one seems to want to address it.
P.S. I posted this message in another topic, just hoping to get some resolution from it HELP!!
Hi guys,
can someone tell me how I can enter the PERF FACTOR in to MCDU ?
A320 v3.4 public beta, X Plane 11.32.r33.
Hi guys,
Hi, I'm writing this just to report an incompatibility between the last beta version of the A320 Neo and the TerraMaxx plugin: the DCDU doesn't works properly (sincerely, it doesn't work at all) when TerraMaxx is operative.
Obviously I've also reported the problem to the plugin's owners.
Regards.
Hi everyone, just having a massive problem with my A320. On take-off the aircraft loses its heading, the landing gear and the flaps cannot be operated anymore and after landing the landing gear suddenly the horizon is back and the heading and control works again.
Does anyone know this error?
do not use latest beta, there are bugs with lots of plugins and aircraft. JAR team is working on a beta update, to be released when a stable .35 version of X-Plane gets out
How is this fps wise? so far V3.2R2 gives me decent fps but newer updates are horrible
