Re: JD320 v.3.4 public beta
paolomazzoleni99 wrote:
Another bug is that after problems are solved, warning messages (ex. "overspeed") stay on the ECAM and don't disappear
This is normal, the warning you have to read and then pressing the CLR cleaned with ECAM.
It works, thanks.
Still trying to figure out the sounds bug
52 (edited by paolomazzoleni99 2019-03-02 12:18:35)
Here's a link of the video I recorded of the a320.
https://youtu.be/0sgI6LV-q-s
As you can (can't) hear there are no sounds of a lot of buttons/switches.
How can I fix this? Or is this normal?
53 (edited by paolomazzoleni99 2019-03-05 17:28:08)
No-one else with my same issue? Already tried previous versions of the A320 but no fix, also tried to download the plane from different browsers. I have the same problems (but very less - a few sounds) on the A330
As far as I know, these sounds come with the BSS sound packet.
Beta 4.3 crashed when push the button on display on the metar sign. No metar aviable Sim crashed
Xplane 11.32 version
I have reinstalled the Aircraft not worked.
No, they are default sounds
ASISA1X STAR doesn't exist on RWY 18 SACO. You have to add FIX manually and square angle is builded between CO801, IREQUI and CF18. The aircraft lost pattern and start to turn in circles on final approach.
58
AUTOLAND blink in red light with AP off
59
BBS sound news - for everybody who asking about fixing sound for JAR 320 v 3.4
Link to BBS news:
https://fr-fr.facebook.com/pg/BlueSkySt … e_internal
Hi Team,
I recently installed the a320 version 3.4 public beta and unfortunately the toolbar ( parking, checklist, etc) doesn't appear anymore automatically on my screen like before. May I recover this configuration ?
Greetings maunouf
61 (edited by euroking2018 2019-03-08 17:21:45)
With the latest Nvidia driver works sound again.
Fps 31 im cockpit very good.
X - Plane 11.32r2.
greetings Martin.
maunouf wrote:
Hi Team,
Greetings maunouf
Check MCDU Menu on FMGC
maunouf wrote:
Hi Team,
Greetings maunouf
64 (edited by euroking2018 2019-03-10 18:45:37)
Departure airports in the ND not more visible.
Aerosoft NavDataPro 1903.
X - Plane 11.32r2
http://jardesign.org/forum/img/m/7500/t/p1d5keipmn1jsn9u41bv11jmjc403.jpg
http://jardesign.org/forum/img/m/7500/t/p1d5kefd5b1q7212982rjftr1u75.jpg
greetings Martin.
wher can i find v3.4 beta because in the download page it downloads v 3.3
what to do need help
on the first page here.
67 (edited by sandeepkr 2019-03-11 07:18:14)
thanks for reply
68
I did a flight today from EGLL to EHAM in XP 11.32r2 using X-Life v090219 in the A320 v3.4b3.
No problems during the flight, big problems on landing as it was very windy, rubbish landing. ( All down to me.)
I really miss the BSS sounds, hopefully that will be sorted soon.
which AIRAC cycle did you install, 1903 ?
NavDataPro or Navigraph ?
With NavDatPro works flightplan not correctly.
greetings martin.
Hi Martin, I used Navigraph 1903. It worked fine with no problems, even though the wind was trying to blow me all over the place.
The A320 update is looking good, I like the new setup, but via the MCDU you can still use the old setup.
The only thing I would like to see is the ability to have different MCDU screens showing and nav screens.
71 (edited by euroking2018 2019-03-12 21:16:43)
Definitely,
JD320 v.3.4 public beta not working with NavDataPro Cycle 1903 properly.
In the flight plan are incorrect  VIA´s inserted and departure airport is are not in ND visible.
The Cesna 172 from Laminar Research work with NavDataPro excelent.
greetings martin.
72
Hi all
I am using jar320 3.4 b3 with the BSS pack.
and xplane 11.32. Everything works correctly, except that it is heard all the time, the characteristic noise it makes when turning the knob of the course or speed or height. The truth is that it is a bit unpleasant.
It happens to someone else?
With the previous version of the 320 it did not happen
73
juanra100 wrote:
Hi all
Do you mean you can constanly hear the knobs turning but you cant see them turning?
If you do, i have that problem i just scroll all the knobs on the autopilot and then it stops it.
74
Look at Darko24 post 59. It is a known problem with BSS sounds on this update, apparently BSS are working on it.
juanra100 wrote:
Hi all
Same problem here.
