Re: JD320 v.3.4 public beta
The GENERATE FLIGHT PLAn - does not generate a flight plan!
E.g. If I enter the dest and arr airport in the INIT page and then click generate flight, it dos not automatically generate it like it does in A330.
Please helppppppppppppp!
you may skype me j.a.romanov  with this
The metar update does not work.
It says NO METAR DATA
I am using FSGRW weather engine with SkyMaxx Pro and Real Weather Connector
Привет как у него обновлять базу airac ? Папки _NavData  нет вообще?
30
Translate:Hi, how is it to update the airac database? Folder _NavData not at all?
Airac is take from GNS430, they don't need own data. Upadate GNS430 if you have old ariac.
claytonfreitas360 wrote:
Hello Srs. Problem with the BSS sound package. Does anyone know how to fix the problem?
here you have a solution, erases these files and is ok
Look like this strings make HDG sound at /plugins/BSS/cockpit/sound.cfg:
# FCU push/pull rotation ################################
type=3d
play=once_when_drf_change
filename=rotatefcu.wav
play_drf=sim/custom/xap/fcu/alt100x
play_drf=sim/cockpit2/autopilot/heading_dial_deg_mag_pilot
x_position=0
y_position=2.14
z_position=-14.14
vol_int=1
vol_ext=0
until new version of BSS will come you may modify it to:
#type=3d
#play=once_when_drf_change
#filename=rotatefcu.wav
#play_drf=sim/custom/xap/fcu/alt100x
#play_drf=sim/cockpit2/autopilot/heading_dial_deg_mag_pilot
#x_position=0
#y_position=2.14
#z_position=-14.14
#vol_int=1
#vol_ext=0
I have 1813 there. The plane does not see it
33 (edited by Patrick F 2019-02-23 11:26:34)
For me I have some items found / some change requests :
a) in VR (Oculus Rift) the V/S knob should change with higher values. It takes too much time to change V/S value in selected mode
b) the aircraft drag on ground is a bit too high (even not fully loaded) - you need too much power to get the lady rolling (IAE engines can move the bird at a little bit above idle - CFM engine need a little bit more thrust than IAE  = ~ 30 %)
c) taxiway rolling : you need too much power (37-38 %) - normally it is less / @ idle (depending on weight)
d) on descend and approach (@ 800-1100 ft/min) it should need to give it a little bit more thrust (instead of idle position)
e) in VR there seems to be no click spot for ground service / gpu. It would be nice to have something like this (for example an unvisible click spot @ the left speaker or air vent/ demister)
Regs
Patrick
Do you have GNS430 right set: x-plane\Custom Data\GNS430\ariac data
Corrected. thank
36
Regs
Patrick
I second b) and c). Also at managed descent the PFD states "THR IDLE" where it's obviously not.
37 (edited by dombarras 2019-02-25 20:25:19)
Hi, I juste made the upgrade but now, the little box on the left sight of my screen, just disappear. Can you help me please? thank you
this box: http://zupimages.net/viewer.php?id=19/08/gcus.jpg
[Update] Sorry  Found my mistake !! I've to read the manuel better the next time big_smile
I'm having a problem with radio tuning, when I try to set the standby frequency, it locks on some combination of 000/001.00/01
I'm crashing on departure, it doesnt just crash my Sim it freezes my pc.
The log.txt does not say anything, it just ends without saying anything.
If anyone could help it would be appreciated.
P. S Ive tries without plugins and custom scenery and deleting prefs and shader cache
40
I'd suggest a clean re-install of the aircraft. To make sure it is related to the JD A320, also try another aircraft if you haven't already done so.
41 (edited by martinlest 2019-02-25 17:06:49)
Getting used to the changes in the FMC (no problems so far - I always import an existing flight plan, BTW - though I am only just started testing and flying) - thanks for the update.
One question though - a detail really, but the change makes me wonder..... When I get to the PERF page, LSK 3R, FLAPS/THS used to have '2/UP0.0' as default. It's now blank. Is this feature now modelled and waiting for user input? If so, how do I know what value to put for the THS? Just leave it at UP0.0? That is quite a rare setting though - more usually something like DN0.2, but if FLAPS/THS isn't modelled in the a320 I might as well just leave it as it is (or do I at least need to add a flaps setting, 1 or 2 ?).
AFAIR, after setting fuel, PAX and cargo as well as the FP, you just click LSK 3R and the field auto-populates
43 (edited by martinlest 2019-02-25 19:51:54)
So it does! OK, thanks. Only problem is that in the previous version, changing this value from the default always made the aircraft difficult to control on takeoff - the pitch was all wrong. with the plane going nose up or not taking off at all. So I just used to leave it at 2/UP0.0.
Need to test this later on v3.4 - maybe that has been fixed. Will post back...
EDIT: It worked beautifully at takeoff! :-)
44
Testing flights with v3.4b3 is run well, only know problems with BBS sound and sometime joystick, when I go with Thrust levers to reverse, increase map range.
In following link you can see one of my flight using all JD plugins - copilot, FM cars, X-life and ground handling.
In this flight i follow request of x-life, excepted arrival STAR, because he gave me the not usually arrival from ARLON.
https://youtu.be/YMUhlnEsr4g
45 (edited by paolomazzoleni99 2019-03-01 16:01:34)
JAR A320 v3.4 public beta.
I normal hear engines and other sounds (like lights switch (taxi, landing etc.)) but no sounds of:
- overhead click
- fmc buttons
- weather radar switches
- switching on radios
- baro button
- radio frequency selector
- parking brake
Am I the only one with this issue? I am using XPRealistic but I already tried switching it off and nothing changed. Also internal sounds are on in X-Plane 11 settings.
+I am not using BSS
- overhead click
- fmc buttons
- baro button
- parking brake
+I am not using BSS
Let the co-pilot do the work and you will hear his voice...
- overhead click
- fmc buttons
- baro button
- parking brake
+I am not using BSS
Well that's not what I want to do. I don't want to use the co-pilot but I want to hear the sounds I paid for included in the aircraft
48 (edited by laohu314 2019-03-01 20:18:25)
If you had previously installed BBS sounds do a complete clean install of the aircraft. If not, just switching XPRealistic off won't solve a problem if it causes one. You need to remove it from the Plugins folder before starting X-Plane. In general, if you have a problem with an add-on that others don't have, then it is most likely due to your configuration. Therefore, to find out what causes the problem do the following:
1) remove all 3rd party plugins from the plugin folder and restart X-Plane. If that resolves the issue you know it is one of the plugins you removed.
2) Add them back one by one and observe when the problem comes back. Then you know what causes the problem.
If removing all 3rd party plugins doesn't resolve the issue then it is either a X-Plane setting that interferes or a setting in the aircraft itself.
3) In that case I would look into sound settings in both X-Plane and the aircraft.
49 (edited by paolomazzoleni99 2019-03-02 01:31:37)
Another bug is that after problems are solved, warning messages (ex. "overspeed") stay on the ECAM and don't disappear
50
This is normal, the warning you have to read and then pressing the CLR cleaned with ECAM.
