Topic: Installation Problems
Hey guys,
I have recently bought my first X-Plane 11 Aircraft Add-Ons: the a320 and the a330.
After I read the installation document, I put the a320 folder in the right X-Plane folder.
Now I started X-Plane and chose it.
But instead of an activation window, some errors are appearing:
- "a320 systems (SASL) plugin not activated"
- "Please check your aircraft installation"
- "Please check whar your aircraft was activated"
- "If activation window does not appear please contact support.jardesign.com"
If you can help me, please try to use easy english or german, because my skills are not that good.
Re: Installation Problems
Another thing that I don't understand is, that even though I use windows, the unzipped a320 folder is named _MACOSX. Is this normal?
After unzpping you get two folders : _MACOSX for Mac user (if you use Window you can delete it)
                                                 And  "Open and read me" folder in which you find a A320 (or A330) folder to be installed in x-plane 11/Aircraft  folder …
You could have put forwarded a320 folder in X-plan folder. Things regarding developing this forum should be elaborated and students can get lucky pants bingo promo code at gamblizard.com/casinos/lucky-pants-bingo-bonus and get help to play casino. These installation problems are usual and can be resolved easily in a better way. Thanks for sharing.
