Re: JD320 Airliner ver 3.3 r1,2,3 WIN/MAC 64 bit (X-Plane 11.30)
Calibra44 wrote:
Still the problem with the AP display/screen, it stays dark in every situation.
Tried everything i could imagine but no change.
Had to go back to the older version of the A320 sad
Hope this will be fixed soon.
Knob underneath the cockpit smile
X-Plane 11.30, JarDesign A320, Jardesign A330, Jardesign X-Life Deluxe, Jardesign Ground Handling Deluxe.
zanesk wrote:
Amazing work with this update jar, the enhancements with the cabin are great, and in VR this works wonders. One question though, I've been struggling to figure out how to adjust the cabin lighting, is it even possible?
I believe it's automatic and changes LED color in different phases of flight.
53
I just took a flight in the NEW A320 version 3.3r1. Just WOW with the visuals and flight model. If nobody else noticed, the cabin LED lighting and interior have changed. The seats now have screens at the back that show a moving camera view of the scenery ahead of the plane. Great job JAR team!
However, I just have one issue and hope it will get addressed. When I was landing and on final approach, as I got close to the runway the aircraft became uncontrollable and started to take a bit of a nosedive into the runway. This was an issue in previous versions. I couldn't flair like the plane should or like it does in your JAR A330 aircraft. Please, can your team look into this? I don't fly the competition's A320, I fly yours and LOVE it! Please fix this for the next update. Best regards.
So far today I was able to make three short flights, each was nice, however, I've been having some problems withe the fmc in this update. The main one is that route discontinuities are not clearing, specifically the one I get after a runway when using no sid or transition. I've tried many things, and no success yet, any one else having this problem?
You can not clear discontinues if you have no SID routes. No SID means no SID so in this case you take off from runway , take some altitude and then manually turn to direction to point after discontinuities. Then press DIR on fmc and go direct to this point width autpilot.
This update is a good step in the right direction,
i got my first simple test flight down without problems or SASL errors.
(LOWK 10/LOWG 31 via ABIRI)
This is the first time with this aircraft
Merry christmas
X-Life Deluxe
GHD
FMCAR
JD320
mumax wrote:
I just installed this version.
When I start from cold and dark the FMC will not activate and stays dark.
No Speed, HDG or ALT is enterable.
I am having after the new installation more or less same result with display and gages. Can not click on them.
58 (edited by dron420 2018-12-24 15:13:11)
Ypu can manually switch on main cabin dome light by this button at attendant panel.
http://ipic.su/img/img7/fs/a320neo_186.1545664318.jpg
59
My older A320 version has an issue with the altimeter. So going back does not solve the problem. Hope JAR fixes it.
Precision of pressure set?
61
currently, I use X-Plane 11.30 Beta. After installation of the JD320 Version 3.3r1 the frame rates are going down. From 45 (JD320 Version bevor 3.3.r1) and more to max. 30/32?  What is the reason?
WIN 10 64bit
I7-7700
Nvidia 1070 GTX
RAM 16 GB
Samsung SSD M2 / 500GB
Thank you for your support.
Merry Christmas
Thx but already solved as you can read some posts below.
Greetz
Just started "flying" but really like it!
It is really the brightness...Had the same issue and i was not able to find the button to light it up. The problem was a "wrong" ankle of view so it never appeared active.
Changed my cockpit position and it worked.
Just a userproblem, not as i thought an update issue. wink
Everything works fine!
64 (edited by Teddit 2019-01-03 04:58:59)
Hello.
Merry Christmas to all.
Just upgraded over to the new ACF, so far so good.
Working well with BSS Soundpack, except having lost their usual Spirit Airlines commentary. Is this a BSS fault?
Also, when adjusting flaps for T/O, I am getting this error on the ECAM (see attached screenie), is this known?
Part from that, everything else is baller, loving the new little updates throughout the ACF.
https://i.imgur.com/QEZCMv6.png
Happy Holidays, You guys deserve the best!
http://jardesign.org/forum/img/m/2572/t/p1cvke0osene61ob71qi11v9r1vsm3.gif
AMD 1090T 3.2 GHZ
16 GB DDR3-RAM
AMD Radeon R9 390 8GB GDDR5
Windows 10 Pro 64 Bit - X-Plane 10 and 11
66 (edited by stivan 2018-12-26 18:22:43)
My problem is that im not getting engine sound with 3.3 and this plugin https://github.com/parshukov/Rendering- … 2/releases
Is there a conflict here ?
67
I have a question! Why can not you still enter your complete route in the FMC (MCDU), on the Airways page, as in the real Airbus? Each airway must be entered individually in the Jar A320. That's me, not known from a real Airbus.
68
Thanks a lot for the team with this update which seems to be well done with lot of improvement, but I encounter a problem with performans. I can't go over 16 fps while with the previous v3.2 r2 I've got about 40 fps with same settings and same scenery, do you have some ideas without setting less rendering options ? X-plane version 11.30 beta
stateless_01 wrote:
Dear Jardesign team,
between the last used version 3.30 r3 and the current download version I have fps drop of aroung 7-10 fps, all the time, in all situations.
So I have to go back to the older version to be able to use it. ?
So I am the only one with FPS drop after the update?
No, you are not the only one.
I wrote about the same problem 2 days ago.
I still waiting for an answer.
71
When you say if we have cockpit textures, we need to delete them. Is that within LiveryName>objects?
72
Need do check your custom liveries folder and if it contain any custom livery textures need to del them, since in this case old textures in livery folder has priority over new one in object folder and you have visual issue when old textures are not match new 3D.
73
You shouldn't have any FPS drop with new version, but we are working with special optimized update which has target to increase FPS, especially for low spec PCs (the rest as well of course).
74 (edited by dron420 2018-12-27 18:03:05)
Do you know that you can type all the points directly on main flight plan page just type next point and then click on LK opposite previews point, so you can insert all required points without limitation (if all points (fixes) on the same airway just enter last one).
Just did a full ILS landing about 10 minutes ago while flying in absolutely terrible weather. The plane handled perfectly and the autoland was spectacular. It definitely seems like this recent update fixed most kinks when performing an autoland. Great job!
