126
Re: XP11 JD330 v.3.1 r1, r2, r3
Oscoz wrote:
Running this latest version without copilot plugin.
Still missing the following sounds:
"Before start check list completed"
"After start Check list completed"
"Flight Controls Check List not responding by (FO)"
"Parking check List completed"
"Secure the aircraft check list completed"
"Nice Landing"
"Approach checklist completed"
Those are not triggered anymore.
Can you check on that?
Tks
Yes, I miss them too.
It would be really, really nice to have those callouts back. smile
I have recently upgraded the A330 from xp 10 to xp 11.
Every time I try to load the A330 the sim immediately crashes to desktop.
Reading the notes in the support section hasn’t helped.
Can you pleas advise how I can get this a/c running?
I am using the latest Xplane 11 (not beta) with the latest Mac OS.
I look forward to a response please.
Please post your log.txt
Please save your log.txt just after crash happen and send it to www.support.jardesign.org
130 (edited by shpion-n 2019-03-16 22:18:26)
Уважаемые коллеги, у меня вопрос по поводу перелёта трансатлантический, хочу пролететь маршрут по UUEE-KJFK - но возникла проблема, PFPX рассчитал маршрут:
AR06E AR FE3T OBELU B239 AJ R900 SIFON B903 ATLUM T561 LEDUN N872 EVIRO Z155 TOGMI Z265 TIGBA Z277 ABADA DCT 65N000E 65N010W 65N020W 64N030W 62N040W 58N050W DCT HOIST N598C QUBIS DCT PQI J55 ENE PARCH3
Меня смущает данные координаты 65N000E ну итд как их забивать в ручную? Пытаюсь не в ручную, а загрузить маршрут самлёт не даёт и выдаёт ошибку (скин прилагаю) самолёт А330 Джар (купленный)
Как победить данную проблему!
https://pp.userapi.com/c851024/v851024842/dc7de/crDbwhACq0U.jpg
Вожу данные 6500N другая ошибка
awy/wpt mismatch
Базы обновлены! через Navigraph FMS Data Manager
awy/wpt mismatch
Need use "/"like:
4600.12N/100.00E or 4600N/100E
where 4600.12 mean 46 deg 00.12 minutes
132
After updating to V3.1 R3 the A330 does not accelerate after passing acceleration height.
Any idea? Is anyone having the same issue? Everything worked fine in R1.
133
Still having big issues using the recommended download GHD with the latest version -313 of the A330? the two separate systems is confusing the running...  if you use the on board FMC menu selection you get GHD items that are not on the menu i.e. Fire Truck, Ambulance...  but you can't "hide" them with the control panel either? they just restart positions? GPU doesn't work from the FMC and then only from the widget? try to hide some items then you hide all...
http://jardesign.org/forum/img/m/30/t/p1d6esfhqcq3dpmkcct8261kdv3.jpg
http://jardesign.org/forum/img/m/30/t/p1d6esfhqc48018bj183n15arjhe4.jpg
If you have both GHD and the A330 you need to use only one access point for the GHD, both as they are different is confusing the system?
134 (edited by mertovic23 2019-03-25 18:03:01)
Why Jar doesnt make  A330/200-300-GE-PW engine option ?
135
yes, please make a A330/200-300-GE-PW engine option, it would be nice and many ppl would like it!
136 (edited by Webrichard 2019-04-02 18:42:40)
Hello! If anyone can help, I appreciate it. I have a bug when I make the LEBL / KJFK (LEBL DCT NANSO N82A KANNI DCT PLYMM STAR KJFK) flight. The fuel balancing information comes out of nowhere when I arrive at exactly 1963nm for NANSO on the N82A aerovia during the flight. With this, the velocities and FL are added. I tried 5x and the error happened in the same position I mentioned, 1963nm for NANSO. I tested this route with other planes and it worked without problems. Thank you for any help.
http://jardesign.org/forum/img/m/7927/t/p1d7fll75r1ohbbohi036raqvv3.png
137
I have updated to the latest version and now you can not hear the sounds of the engines, and other cabin sounds. Why does this happen? thanksss
138 (edited by Daniel.Kamer 2019-04-07 19:13:43)
Can someone advise how to overcome the "No sound" problem?
With a clean plane install I have no sounds at all.
With the BSS package I have sound but missing GPWS callouts, Fasten seatbelts chime, No smoking chime.
Using X-Plane 11.32.
Thanks in advance.
139 (edited by wesader 2019-04-08 04:10:14)
Thanks in advance.
Hi Daniel i could have solution in u issue. For me it helps when i remove lot of ground traffic from plugin list, so what i was done. i rename inside of custom scenery from all custom airports plugins folder to _plugins. for example inside of custom scenery -> EBBR -> plugins there is ground traffic plugin and x-plane 11 load all to system when u start flying. so there could be hundreds ground traffic plugins loaded, and that cause issue with JD A330 sounds, those could be causes issue also other planes. sry by this long novel, but i am sure this help u. smile
My Fleet: FF A320U, FF A350, FF B763, FF B757v2 ext, JAR A330, JAR A320, ToLiss A319
Utilities: X-LIFE Deluxe, FMcar, EFASS, XEnviro, X-Camera
Hi Wesader,
Thank you for your suggestion. I will check and disable any traffic plugins and see if it helps.
This is the only plane that has issues at the moment.
Daniel.
Hi Wesader,
Unbelievable!! I went trough every plugin folder inside my custom scenery, changed the folder name to "_plugins" and there you go. Sounds work perfectly! I guess I owe you a beer.
Thank you for sharing your knowledge. I really appreciate it.
Well done! smile
Daniel.
142 (edited by ilankrt 2019-04-11 16:13:46)
Daniel.Kamer wrote:
Hi Wesader,
Well done! smile
Daniel.
Maybe someone knows if we can put one GroundTraffic plugin folder into XP/Resources/Plugins folder instead leaving them all in many scenery folders?
X-Plane activate at first all plugins located in the Plugins folder so that must be working?!  My problem is that I have already all X-Life scenery folders in Custom Scenery folder so I cannot test this case....
143
Maybe someone knows if we can put one GroundTraffic plugin folder into XP/Resources/Plugins folder instead living them all in many scenery folders?
Unfortunately not. These are per airport plugins. Not a great idea.
144
Ground Traffic is a plugin for scenery developers and needs stay in each scenery folder.
145
So what about post 139 ?
146
I there is a plugin folder with the GroundTraffic plugin in it in a scenery folder then Groundtraffic will work. If there is not such a folder (i.e. it has been renamed to _plugin) then GroundTraffic will not work for this scenery.
OK thanks, understand...
148
Yup, ground traffic plugins is inside every custom airport scenery.. well almost depend to dev if he or she made it. however, yes if u rename inside of "custom scenery airport" "plugins" folder to "_plugins", then that specific airport ground traffic won't loaded to x-plane 11 plugin generator.
This happens every time I load up the aircraft. I have the C+ 2010 thing and latest Java but I dont get the activation window. My JAR A320 Works fine but this doesnt for some reason. Any advice?
150 (edited by NotAlpha 2019-04-16 19:22:11)
pic wont post but im getting the SASL error
