Re: v.3.1 beta 1, 2, 3 public beta-tests
marccarette wrote:
Send my log, no résult, speech,ok,
JD SPEECH Plugin: Get MSG: contextpath>E:\X-Plane 11\Aircraft\JD330XP11\plugins\copilot_main\
FMGS: 0 : JARDesign FMGS  plugin ver.V3R6-230818 detect crash.
FMGS: 0 : Memory dump saved to fmgs.dmp file
FMGS: 0 : Please send this log.txt file and fmgs.dmp file (from X-Plane folder) to support@jardesign.org !
Please check what you really install English lang/ pack like described here http://jardesign.org/forum/viewtopic.ph … 174#p29174
27
This take flight sim to another level! the concept is brilliant! congrats on that @J.A.Romanov
Still, I can't select female voice, I see the female copilot, but the voice is male. if I go to "select voice" in A330 -> copilot menu I get nothing, no submenu whatsoever...
Any ideia why?
28
Hi JAR,
Excellent work. For me everything works fine. It is nice flying with some help. Keep going with your plans for future, you have brilliant ideas.
29
Any ideia why?
You need open Windows settings, find speech settings and check default installed voiced. Usually it is Zira and David on Windows 10. If not - it may be installed.
30 (edited by jcdp 2018-11-06 11:30:14)
Using English (US) langage after having turned on the recognition voice button (not so easy to find) everything works fine with w10 .
Thanks for your help .
The use of copilot version is very nice . That is a very good idea to Implement this .
Today I'll try to give command to copilot PACKS OFF, but is no response - even with menu. If I give command PACK ONE OFF or PACK TWO they work. Packs are not included in any procedures, but after take off copilot automatic turn packs on as normal.
32 (edited by laohu314 2018-11-09 01:10:28)
That's because there is no command "Packs on" nor "Packs Off". Only "Pack 1/2 on/off" exist at the moment. I'll try to make one tomorrow to turn them both on/off.
33
Ok, beta 3 is posted, need reinstall full aircraft.
beta 3:
+ some kind of crashes fixed
+ fmgs improved (Maximum FL indication, Second flight ready w/o reload, click sound repair)
We also expect next beta 4 with AirFMC plugin compatible.
Thank you!!!
Did a quick test flight with beta3. Works pretty well. A few things didn't work with the 3D co-pilot (probably my fault)
1) Before Take Off Checklist Below the Line (BeforeTakeoff_BL.txt) did not execute. Should it execute automatically or does it have to be manually started?
2) I made a command to turn on/off both Packs which worked when I executed it through the menu but not with voice command, even though the voice command was properly recognized by the speech engine (command appeared above the microphone icon)
35
Ok, thank you for report!
1.Manually
2.May be some other command use this text
To debug any for this plugin you need use Developer=1 in settings file and also, you may do execution flow step-by-step (call next string using command what you may find in commands list)
36
Before take off checklist is functioning by voice command on my test flight with v.b3.
Packs 1 and 2 on/off is also functioning by voice command
If co-pilot don't react try to restart co-pilote (on menu)
37
1.Manually
Thank you. I suspect that "Packs on" may be too similar to "Packs one on" but I will play with it a bit.
I have already changed the command "Packs one/two" to "Pack one/two" but still ...
38
ComRPM wrote:
This is an amazing idea!
Can the system be updated by users to support other languages?
As you know, Airbus procedures based on English - SOP, Checklists - all use English only. And for this aircraft - English only can be used. For other aircrafts (future task) - we will look what we can do.
Hello Mr Romanov,
this is right all speaking in Air is English! this is a not my big Problem, my problem is i from Germany and my PC is not allone for me i can not changing everyone Overlay Language to english, this is a Problem from Windows to!! (overlay German, speech english)<-- this not allow Windows.
a little thing to, after the language changing all activations broken (i can not say,come from this)
About the new Copilot its realy nice
sorry for my bad English
lg Manuel
39 (edited by silverpnt01 2018-11-15 14:16:59)
Maybe you can fix the fluttering of the flight control surfaces that result in loss of control and crash the aircraft.
I brought this up via email and was told it could be plugins, pilot error, weather etc. The actual problem is the aircraft it is unflyable.
X-Plane 11.26r2 (build 112601 64-bit)
Better push back plugin, Navigraph Plugin, Ground Handling Plugin (JarDesign)
Aircraft JAR A330.
Example #1 - no weather issues at cruise altitude with flight surfaces oscillating, resulted in autopilot disconnect aircraft nose up and complete loss of control.
https://clips.twitch.tv/FrailVivaciousSparrowPupper
40
Example #2 -- starting at 50 seconds look at the flight control screen.
https://youtu.be/NySTBvPcX44?t=54
41
Without the log.txt file it is nearly impossible to check what is going wrong .
Aircraft JAR A330.
Well, 37000ft 250kt (524kt on your info line ?!) 60kt tailwind that means that your true air speed is under 250kt. No surprise that your airliner stalled and crashed....
From you video I see that you have no idea how to fly this airliner model. Further I son't know if it is an XP10 model using in XP11 ? You haven't offer any further information. My tip look at tutorial videos' read manuals and lear to fly !
44
Aircraft JAR A330.
Sorry silverpnt01 JAR A330 is  very nice to fly and your opinion that is unflyable is funny.
I'll fly  every day with this plane without problems that you say and show in yours videos. Today I fly short flights LOWW-EDDF-EHAM-EGLL ( 4 takeoff, 3 landing, real weather) without any problem. Everything works perfect including copilot.
When i look yours videos, I've seen, that pilot is not fly, but it looks like a gambler pushing the buttons on the slot machine with no idea what to do.
I agree with Ilankart and their counsel to look at tutorial videos' read manuals and learn to fly !
45
Hello Mr Romanov,
lg Manuel
Yes, this is true, but voice recognition settings on Windows is Microsoft software and user may setup it only with this way. We cant affect this. Yes, we create version based on Google speech/recognition version. Just nothing need to setup there. But this version is tooooo expensive - about 10-15 USD every month for every user (crazy). But Microsoft/Apple recognition version is already included in Windows/MacOS and recognition engine is free for user.
46 (edited by Vrumugun 2018-11-16 14:07:44)
Hi JAR wink
i did my first flight with my new Co-pilot today. It's a very nice feature. I like it very much!
Installation did work without any issues (i followed the instructions posted here in the forum).
The following remarks:
- I had some trouble with the "gear up" and "flaps four" / "flaps full" command. Maybe i need to train the voice recognition some more. "Landing gear up" did work fine.
- There is a small mistake in the procedures when the landing gear is extended. Nose light switch should be switched to "Taxi" instead of "On", see picture: https://imgur.com/a/sWTG1CE
Keep up the great work!
Simon
47 (edited by jcdp 2018-11-16 14:09:17)
Ready to leave the ramp , after having released park breaks , the aircraft v3.1 b3 went backwards ...with no possibility to change anything .
I deleted the aircraft and reloaded it, reinstalled preferences … without success .
I can't put here the log.txt file anymore .
Are you using 11.30b4? Maybe try it in 11.26.
49
Well, I am a bit stupid … the issue does not come from the aircraft at all …
Everything is normal , aircraft goes backwards once park breaks are released because of the slope of the ground near the ramp .
This comes from  orthophotos …
JAR has found it at first glance … thank you Mr Romanov .
And thank you Mr Vrumugun for your answer .
Any way I found these message in log.txt :
JD COPILOT Plugin: ReadFileListFromFolder=D:\Desktop\X-Plane 11\Aircraft\JD330XP11-Copilote\plugins\copilot_main\custom/events/Anti ice/
JD COPILOT Plugin: ReadFileListFromFolder=D:\Desktop\X-Plane 11\Aircraft\JD330XP11-Copilote\plugins\copilot_main\custom/events/Approach/
JD COPILOT Plugin: Error in script - cant find dataref: APPCLEXEC
JD COPILOT Plugin: ReadFileListFromFolder=D:\Desktop\X-Plane 11\Aircraft\JD330XP11-Copilote\plugins\copilot_main\custom/events/Checklist/
JD COPILOT Plugin: Error in script - cant find dataref: LANDCLEXEC
JD COPILOT Plugin: ReadFileListFromFolder=D:\Desktop\X-Plane 11\Aircraft\JD330XP11-Copilote\plugins\copilot_main\custom/events/Climb/
JD COPILOT Plugin: ReadFileListFromFolder=D:\Desktop\X-Plane 11\Aircraft\JD330XP11-Copilote\plugins\copilot_main\custom/events/Cruise/
JD COPILOT Plugin: ReadFileListFromFolder=D:\Desktop\X-Plane 11\Aircraft\JD330XP11-Copilote\plugins\copilot_main\custom/events/Descent/
JD COPILOT Plugin: ReadFileListFromFolder=D:\Desktop\X-Plane 11\Aircraft\JD330XP11-Copilote\plugins\copilot_main\custom/events/FMA/
JD COPILOT Plugin: ReadFileListFromFolder=D:\Desktop\X-Plane 11\Aircraft\JD330XP11-Copilote\plugins\copilot_main\custom/events/GA/
JD COPILOT Plugin: ReadFileListFromFolder=D:\Desktop\X-Plane 11\Aircraft\JD330XP11-Copilote\plugins\copilot_main\custom/events/Landing/
JD COPILOT Plugin: ReadFileListFromFolder=D:\Desktop\X-Plane 11\Aircraft\JD330XP11-Copilote\plugins\copilot_main\custom/events/Misc/
JD COPILOT Plugin: Error in script - cant find dataref: GLASSMANUALCONTROL
JD COPILOT Plugin: ReadFileListFromFolder=D:\Desktop\X-Plane 11\Aircraft\JD330XP11-Copilote\plugins\copilot_main\custom/events/Speeds/
JD COPILOT Plugin: ReadFileListFromFolder=D:\Desktop\X-Plane 11\Aircraft\JD330XP11-Copilote\plugins\copilot_main\custom/events/Takeoff/
What could be the risk with "Error in script ….
