Topic: 727 set doesn't work
Hi, I was about to try the 727-200 set, as is supposed to be included out of the box. But it doesn't work: the cars etc don't move. Other sets work perfectly, so no general problem.
Regards, ionfresko
Re: 727 set doesn't work
May be you need just visit our http://simliveries.com/index.php/category/ghd-set... to check what aircraft(s) have compatible sets to work well with GHD. Next you can download .set file and put it to ../X-Plane/Resources/plugins/GndHandling/Sets/Custom/ folder.
If no set there for your aircaft, another way may be used. Open ../X-Plane/Resources/plugins/GndHandling/Sets/Default/ folder and find .set file what may be good for your aircraft by name. Take this file and put it to your aircraft folder, close to .acf file. Next - rename .set file with the same name what used for .acf file. So, if you see b737.acf file you should rename set like b737.set This trick will allow you to try to use any of exist set with any aircraft you want.
Thanks for the answer.
I know about and have checked the simliveries place, where there is no 727-100 set. The reason I asked however was that in the description of GHD, it says that there is an 727-200 set out of the box. Also in the Default sets folder there is a set file named "727", which however doesn't work. Maybe that set file is not compatible with 727 v3?
727SeriesbyFlyJ.set is exist in Default folder
Regards, ionfresko
I understand the issue which you actually mentioned in your post you can take a help of Tp-link Support to solve the issue quickly when I face the same issue I also take a help of this site.
6 (edited by tayler 2018-11-22 16:30:37)
May be you need just to check what aircraft(s) have compatible sets to work well with GHD. Next you can download .set file and put it to ../X-Plane/Resources/plugins/GndHandling/Sets/Custom/ folder.
If no set there for your aircaft, another way may be used. Open ../X-Plane/Resources/plugins/GndHandling/Sets/Default/ folder and find .set file what may be good for your aircraft by name. Take this file and put it to your aircraft folder, close to .acf file. Next - rename .set file with the same name what used for .acf file. So, if you see b737.acf file you should rename set like b737.set This trick will allow you to try to use best dog clippers for grooming reviews and ultimate buying guide set with any aircraft you want.
Thanks for the advice!
